05-19-2008 09:54 PM - edited 03-05-2019 11:05 PM
Please provide the all protocol ports numbers.
05-19-2008 10:36 PM
This link is of good help.
http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
05-19-2008 10:59 PM
What is the port range of TCP and UDP ?
05-20-2008 12:34 AM
The port ranges of UDP and TCP actually the same; that is, they are independent of each other in priciple. So each has a range of ports from 1 to 64K. You distinguish them by the protocol field in the IP header: 6 for TCP, or 17 for UDP.
Very often, however, there are protocols that can run equally over TCP or UDP, and in these cases they usually use the same port number for UDP as they do for TCP. For example, DNS runs over UDP/53 or TCP/53.
Kevin Dorrell
Luxembourg
05-19-2008 10:36 PM
Please refer to this link http://www.iana.org/assignments/port-numbers.
Please rate if it helps.
Deejay
05-19-2008 10:42 PM
This is my favorite site for this, because it also warns you which ports are susceptible to malware.
http://www.bekkoame.ne.jp/~s_ita/port/port1-99.html
Kevin Dorrell
Luxembourg
05-19-2008 10:48 PM
Kevin, so erly??
