Showing results forĀ
Search instead forĀ
Did you mean:Ā
PS-1 not present but giving bad input power
Power supply-1 is not present.Ideally it should give status as Not present but giving  no input power bad which ultimately results in triggering error in monitoring tool. Switch version is 03.07.05E.
show environment all
Switch 1 FAN 1 is OK
Switch 1 FAN 2 is OK
Switch 1 FAN 3 is OK
FAN PS-1 is NOT PRESENT
FAN PS-2 is OK
Switch 1: SYSTEM TEMPERATURE is OK
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  Unknown             Unknown      No Input Power  Bad      Bad      235
Leo Laohoo
Have you tried updating the firmware of the switch first?
No . I have not updated firmware. The cisco ios-xe version is 03.07.05E mapping to ios version 15.2(3)E5. Is this IOS bug?
balaji.bandi
first, i would physically visit and check is the PSU on and Power input connected - if that is all done.
if you have got dual PSU, remove the Power and re-connect and test it.
then above checks done and its bug :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb63422/?rfs=iqvred
BB
