PT, assigning IP to switch using DHCP via router
kalafijoras
Topology:   Router --> Switch --> 2 VLANs. I configured the router as DHCP server to give different IPs to different VLANs. How can I configure router to assign ip address dynamicly by its MAC address.
I was using this for VLANs:
ip dhcp pool vlan12
network xxx.xxx.x.x 255.255.255.0
default-router xxx.xxx.x.x
exit
ip dhcp excluded-address .....
What should I use for the switch?
I have found and didnt work:
hardware-address *MAC*
Thank you.
5 Replies 5
Bilal Nawaz
Hello, Unfortunately - there is no option to create reservations in DHCP in PT - its a limitation.
You may wish you configure an ip address on the switch manually and have a default-gateway to the routers ip address.
hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
still a limitation of PT which is very good for basic stuffs but is very limited in my humble opinion.
I know GNS3 is not endorsed by Cisco but if you can't afford to buy real material this is by far the best tool to learn and experiment.
Alain
cadet alain
-you must look at the dynamic bindings to see the client-identifiers with sh ip dhcp binding command.
- clear the binding with clear ip dhcp binding x.x.x.x command
-configure the host pool with the client-identifier xxxxxx command with the identifier you got from the dynamic binding.
Alain
Hello Alain,
There is no option for this... Unless I was looking in the incorrect place?
ISP(dhcp-config)#?
  default-router  Default routers
  dns-server      Set name server
  exit            Exit from DHCP pool configuration mode
  network         Network number and mask
  no              Negate a command or set its defaults
  option          Raw DHCP options
Thats due to a limitation of PT.
Example, try the debug command, you will see you get two or three options, on a regular IOS you get tons.
As mentioned before, its good for basic stuff, but more advanced it can not handle.
