PTP sync does not work on each port N9K
MichF47603
Hi together,
I've seen any problems with IEEE1588 PTP-Sync on my Nexus N9K-C93108TC-FX (nxos.7.0.3.I7.3).
On some Ports (example: 1/45) won't PTP-Sync work. If i switch the PTP-Client on other Port (example: 1/43) the PTP-sync will work's propertly fine.
The Port-Configuration (1/43 and 1/45) is identical.
What could be the cause for this issue?
- MAC-Table?
- ARP-Table?
Thx,
Michael
10 Replies 10
marce1000
 - You may want to review these bug reports :
                  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb64728
                  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi92409
 M.
Hi M and thx for your Reply.
This Bug don't describe my issue.
If i deactivate ptp on the port - the cisco port doesn't still send PTP (no Announce, Sync, FollowUp) to Client
My ClockDomain is 0
My Settings on the N9K:
feature ptp
clock protocol ptp vdc 1
vlan 99
ptp source ###.###.###.###
ptp priority1 2
ptp priority2 2
vlan configuration 99
  no ip igmp snooping
interface Ethernet1/43
  ptp
  ptp vlan 99
  switchport access vlan 99
  mtu 9014
interface Ethernet1/45
  ptp
  ptp vlan 99
  mtu 9014
Status:
PTP Device Type: Boundary clock
Clock Identity :  ##:##:##:##:##
Clock Domain: 0
Number of PTP ports: 18
Priority1 : 2
Priority2 : 2
Clock Quality:
        Class : 248
        Accuracy : 254
        Offset (log variance) : 65535
Offset From Master : 15
Mean Path Delay : 0
Steps removed : 1
PTP Port Dataset: Eth1/45
Port identity: clock identity:  ##:##:##:##:##
Port identity: port number: 176
PTP version: 2
Port state: Master
VLAN info:  8
Delay request interval(log mean): 0
Announce receipt time out: 3
Peer mean path delay: 0
Announce interval(log mean): 1
Sync interval(log mean): -2
Delay Mechanism: End to End
I checked the Ouptut of Port 45 - there are only sends Announce & Sync, the FollowUp is still missed.
BR,
Michael
          - Check logs on the N9K. too, watch for info's concerning this issue, if any.
 M.
Could you explain which logs exactly do you mean?
I try to create al logfile in the N9K, but there are no relevant Infos in the logfile in \root\log\ (only 3 lines?)
logging logfile ptp.log 7
01 2021 Jun 30 11:34:11 Switch %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on console0
02 2021 Jun 30 11:41:25 Switch %PTP-2-PTP_STATE_CHANGE: Interface Eth1/45 change from PTP_BMC_STATE_LISTENING to PTP_BMC_STATE_PRE_MASTER
03 2021 Jun 30 11:41:29 Switch %PTP-2-PTP_STATE_CHANGE: Interface Eth1/45 change from PTP_BMC_STATE_PRE_MASTER to PTP_BMC_STATE_MASTER
BR,
Michael
 - Possibly and if applicable or possible ,depending on urgency have a go with the latest advisory release :
                 https://software.cisco.com/download/home/286314802/type/282088129/release/9.3(7)
 M.
Hi M,
sorry, but updating the Firmware ist not an option.
It is only allowed, depends on releases the IT-Department, to use nxos.7.0.3.I7.3
How could i identify the cause of the issue?
Thx and BR,
Michael
 - That's  a pity , but I acknowledge it , but note that such issues can be attributed to subtle bugs albeit being documented or not , usually it remains advisory to try a cisco-advisory release , which I mentioned. It all depends on problem-urgency too.
 M.
what i have seen:
- FollowUp is available on Ports 1/1 - 1/44
- FollowUp is not available on Ports 1/45 - 1/48
BR
 - You may find this document informational and or some commands might be applicable to your platform too :
                 https://www.cisco.com/c/en/us/support/docs/ip/network-time-protocol-ntp/212139-Configure-and-troubleshoot-PTP-in-Nexus.html
 M.
sorry, but there are no solutions to fix the issue
