public class A addresses
carl_townshend
Hi all, Can anyone tell me the private CLASS A addresses and the public class A addresses ?
7 Replies 7
amit-singh
Level 8
Level 8
Hi Carl,
Class A ip address range:
1.0.0.1 to 126.255.255.254
Private Adress for Class A
10.0.0.0 - 10.255.255.255 (10/8 prefix)
Rest all the ip addresses are public.
HTH,Please rate if it does.
-amit singh
does that mean Class A ip address range:
1.0.0.1 to 126.255.255.254 are public ?
There are also IANA reserved addresses and this IPs shouldn't be on public internet (1.0.0.0 /24; 2.0.0.0/24 etc.)
check following table
http://ip-lookup.net/documents/Internet-Protocol-v4-Address-Space
So public class are IPs 1.0.0.1 to 126.255.255.254
EXCLUDING address marked as IANA - Reserved from table above
M.
Yes the range 1.0.0.1 to 126.255.255.254 are public
expect the 10.0.0.0 to 10.255.255.254 range are reserved for private network which are not routable on internet.
Rajini
Many of the non-private Class A addresses are reserved for use by the United States Department of Defense, which invented TCP/IP.
Trivia buffs, feel free to rate this post.
Is 127.0.0.0 class A, I know its a loopback address but I always see 0-127 class A, Is this right ?
As originally defined in RFC 790 (now obsolete) class A addresses were 000.rrr.rrr.rrr through 127.rrr.rrr.rrr with 0 and 127 being reserved.
A lot has changed since then and even the term "Class A" is now obsolete. (Worth reading RFC 4632 for the history)
Andrew.
