Public Wireless VLAn able to access Private network
JPCPIA130
I just inherited this environment and came across a problem. We have Vlan20 set up 192.168.20.x for guest wireless and this should not be able to access our private network Vlan10 100.x.x.x. We have cisco 3750x switches and i do not see ip routing set. So i do not see how this is possible. Any help would be really great!!!!!
Here is my switch config. port g1/0/46 has one of our aironets connected
no service pad
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
switch 3 provision ws-c3750x-48
switch 4 provision ws-c3750x-48
switch 5 provision ws-c3750x-48
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/46
 switchport trunk native vlan 10
 switchport trunk allowed vlan 10,20
 switchport mode trunk
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface Vlan1
 ip address dhcp
 shutdown
interface Vlan10
 ip address 100.100.10.235 255.255.254.0
interface Vlan20
 no ip address
ip default-gateway 100.100.10.254
ip classless
no ip http server
ip http secure-server
ip sla enable reaction-alerts
logging trap errors
logging facility syslog
logging 100.100.10.213
monitor session 1 source vlan 10
monitor session 1 destination interface Gi1/0/47
ntp server 100.100.10.254
end
and this is the ASA
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
no names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
 switchport access vlan 10
interface Ethernet0/2
 switchport access vlan 20
interface Ethernet0/3
 switchport access vlan 30
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 shutdown
 no nameif
 security-level 100
 no ip address
interface Vlan2
 nameif outside
 security-level 0
 ip address External Adress
interface Vlan3
 shutdown
 no nameif
 security-level 50
 no ip address
interface Vlan10
 nameif inside
 security-level 100
 ip address 100.100.10.254 255.255.254.0
interface Vlan20
 nameif guestnet
 security-level 50
 ip address 192.168.20.254 255.255.255.0
interface Vlan30
 nameif DMZ
 security-level 50
 ip address 192.168.30.254 255.255.255.0
access-list inside_access_in extended deny tcp host 100.100.10.242 any eq www
access-list inside_access_in extended deny tcp host 100.100.10.240 any eq www
access-list inside_access_in extended deny tcp host 100.100.10.208 any eq www
access-list inside_access_in extended deny tcp host 100.100.10.204 any eq www
access-list inside_access_in extended permit ip any any
access-list dmz_access_in extended permit tcp any4 object CITRIX eq 1433
access-list dmz_access_in extended permit tcp any4 object 100.100.10.3 eq ftp
access-list dmz_access_in extended permit tcp any4 object MAIL eq smtp
access-list dmz_access_in extended permit tcp any4 host 100.100.10.230 eq 1743
access-list dmz_access_in extended permit tcp any4 host 100.100.10.230 eq 1745
access-list dmz_access_in extended permit object-group TCPUDP any4 host 100.100.10.253 object-group APC_Ports
access-list dmz_access_in extended permit icmp any4 any4
access-list dmz_access_in extended permit ip any4 any4
access-list guestnet_access_in extended permit tcp any4 host 100.100.10.219 eq www inactive
access-list guestnet_access_in extended permit tcp any4 host 100.100.10.219 eq https inactive
access-list guestnet_access_in extended permit tcp any4 host 100.100.10.214 eq domain inactive
access-list guestnet_access_in extended permit ip any4 any4
access-list outside_access_in extended permit tcp any4 host 100.100.10.218 eq www
access-list outside_access_in extended permit tcp any4 host 100.100.10.218 eq https
access-list outside_access_in extended permit tcp any4 object 100.100.10.10 eq smtp
access-list outside_access_in extended permit tcp any4 host 100.100.10.219 eq www
access-list outside_access_in extended permit tcp any4 host 100.100.10.219 eq https
access-list outside_access_in extended permit tcp any4 host 100.100.10.146 eq 493
access-list outside_access_in extended permit icmp any4 any4 echo-reply
access-list outside_access_in extended permit icmp any4 any4 time-exceeded
access-list outside_access_in extended permit icmp any4 any4 unreachable
access-list outside_access_in extended permit tcp any4 host 192.168.30.10 eq www
access-list outside_access_in extended permit tcp any4 host 192.168.30.10 eq https
access-list outside_access_in extended permit tcp any4 host 100.100.10.54 eq 100
access-list outside_access_in extended permit tcp any4 host 100.100.10.55 eq hostname
route outside 0.0.0.0 0.0.0.0 externaladdress 1
Jacob Berger
Level 2
Level 2
the ASA should be doing the routing - note interface in vlan 20
and seems like:
is allowing access to internal network
Shouldn't the routing between VLANs be done on the Switch?
when I enter the command
no access-list guestnet_access_in extended permit ip any4 any4
I loose access to the internet along with access to the private VLAN
if the ASA is for internal vlan routing then it should be doning the routing
by the names of the interfaces in the config i suspect its the gateway (but why does  it have internal vlans interfaces configured?)
if so then yes, the switches (3750x are layer 3 switches) should do the internal routing
and the ASA the external
seems like there is some misconfiguration
you didnt supply  much info about your network
but see the following for typical network
see diagram and config
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41260-189.html
in the above your ASA would replace the Router
