(PVID) inconsistency *PVID_Inc Issue
Issue: Vlan 1 is in (PVID) inconsistency state on the Core switch for some access switches trunk ports.
Native Vlan is 1 (same on all the switches)
Find the output below:Core Switch (6513)
SW-Core#sh spanning-tree inconsistentports
Name Interface Inconsistency ----------------------
VLAN0001 GigabitEthernet11/1 Port VLAN ID Mismatch
VLAN0001 GigabitEthernet11/2 Port VLAN ID Mismatch
SW-Core#sh spanning-tree vlan 1
Interface Role Sts Cost Prio.Nbr Type
Gi11/1 Desg BKN*4 128.1281 P2p *PVID_Inc
Gi11/2 Desg BKN*4 128.1282 P2p *PVID_Inc
SW-Core#sh logging
%SPANTREE-SP-2-RECV_PVID_ERR: Received BPDU with inconsistent peer
vlan id 1 on GigabitEthernet11/2 VLAN1012.
%SPANTREE-SP-2-BLOCK_PVID_PEER: Blocking GigabitEthernet11/2 on
VLAN0001. Inconsistent peer vlan.
SW-Core#sh spanning-tree vlan 1 detail | inc 11/2
Port 1282 (GigabitEthernet11/2) of VLAN0001 is broken (Port VLAN ID Mismatch)
BPDU: sent 0, received 1173
Access Switch(2960) :
SWITCH 1 (which is connected through 11/2 of CORE SW)
switch01#sh spanning-tree vlan 1
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 49153
Address 0018.18aa.aaaa
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 49153 (priority 49152 sys-id-ext 1)
Aging Time 300
Uplinkfast enabled
Gi0/21 Desg FWD 3004 128.21 P2p
Gi0/22 Desg FWD 3004 128.22 P2p
" VLAN 1 is root bridge "
Whereas all other Vlans are working normal.
VLAN0100
Root ID Priority 100
Address 0014.f1bb.bbbb
Cost 3004
Port 21 (GigabitEthernet0/21)
Bridge ID Priority 49252 (priority 49152 sys-id-ext 100)
Aging Time 300
Uplinkfast enabled
Gi0/21 Root FWD 3004 128.21 P2p
Gi0/22 Altn BLK 3004 128.22 P2p
On the Core switch:
SW-Core#sh inter trunk
Port Vlans in spanning tree forwarding state and not pruned
Gi11/2 100-105
I have fixed this issue by forcefully allowing under trunk interface(
even though this the default):
switchport trunk allowed vlan 1-4094
After applying the above command, Core switch output changed to and
the PVID_Inc error went away :
Gi11/2 1,100-105
I have solved this issue on 3560 Access Switch by applying:
SW-3560(config)#vlan dot1q tag native
Core Switch Logs :
%SPANTREE-SP-2-UNBLOCK_CONSIST_PORT: Unblocking GigabitEthernet11/1
on VLAN0001. Port consistency restored.
I have many access switches with the same configuration but WHY I am getting this issue only on some switches. I want to know why this
problem is random in nature (occurring on only some switches).
Secondly "vlan dot1q tag native" is not supported some of the access switches(2960) but this command has applied on the core switch. Should I remove it from the Core switch or keep it there? What is the best
practice? But other access switches are working properly without "vlan
dot1q tag native" command.
How can I fix this issue without applying "switchport trunk allowed vlan 1-4094".
This problem is not solved by SHUT/NOSHUT under the trunk interfaces.
All switching are working in PVST+ mode
Anser
5 Replies 5
glen.grant
You will see this if the trunk configs do not match on each end and native vlan mismatches are a cause in a lot of cases . Make sure trunk parameters match exactly on each end including native vlans. Also what vlans allowed across the trunk probably do not match. The switch looks at these if you are using DTP to create the the trunks , its a self protection mechanism. All newer switches including the 2960 support specifying a specific native vlan for the trunks , if none is specified it defaults to vlan 1.
Giuseppe Larosa
Hello Anser,
on an 802.1Q trunk a Cisco switch uses a proprietary version of BPDU to send PVST BPDUs.
This version includes a field that is the vlan-id.
When the external 802.1Q vlan-id is different from the vlan-id in the received BPDU the switch reacts by rising an STP inconsistency.
in this case the switch named
SW-core complains of:
so it says it has received a BPDU with inner vlan-id 1 on vlan 1012.(802.1Q vlan-id).
as a result of this the port is placed in an incostistent state.
sw-core doesn't sends out BPDUs for vlan1.
As a result of this the C2960 sees itself as the root bridge for vlan1 even if it has an high switch priority (probably the result of uplinkfast)
to be noted that when the native Vlan is untagged, a IEEE version of STP BPDU for vlan1 is sent out for backward compatibility with legacy 802.1D devices.
The root cause of your issue is probably the setting
on core switches.
Tagging the native vlan is useful when you use 802.1Q in Q to avoid to expose the inner vlan-tag in the service provider network.
In a normal campus network you should be fine with default settings that is
native vlan untagged.
this is the worst part of this issue.
Also restating the list of permitted vlans may fix.
To be noted that permitting only used vlans on both ends of the trunk is recommended.
C2960 may not be able to run as many STP instances as the number of existing vlans in the campus.
So a trunk allowed vlan list limits the number of STP instances running on access switches and contributes to network scalability.
Hope to help
Giuseppe
briceleck
One way to fix this is to have your customers use "spanning-tree bpdufilter enable" at both ends of the circuit so that their gears don't attempt to send BPDUs across the cloud.
interface GX/X
  description connection to the ISP
  switchport mode trunk
  switchport trunk allowed vlan YYY
BPDU filter will not stop the BPDU's it will just let BPDU's pass without any issues and one of the major causes of loop
hi rsijori
for better accuracy it will make port to ignore any incoming BPDU putting the port  into always forwarding/designated state
