PVLAN & VTP
fabio.marino
Hello i'm Fabio Marino and i'm studying to prepare the 642-813 CCNP swicth exam.
My question involving interaction between private vlan and vtp.
My topology is reported below:
In brief:
---> PC0, PC1, PC3 are in the VLAN 100
---> PC2, PC4,PC5 in the VLAN 150.
--->Requests:
1)  PC1 cannot communicate with PC3
2) PC3 cannot communicate with PC3
3) PC1, PC3 can communicate with PC0
Solution Plan:
STEP1 - Configuring Trunk : All interfacess will carry normal VLAN and PVLAN, so i will use private vlan trunks
STEP1 - Configuring VLAN : I will create VLANs 100, 150 on the switch S3 (VTP Server) with remanings switch set on Client Mode.
STEP2 - Configuring PVLAN: I want to implement the private VLANs in order to satisfy requests 1,2,3. I will put all switches in transparent mode and then i will configure an isolated vlan for PC1 and PC3 and a primary vlan for PC0. I will configure pvlans in  all switches in order to maintain the security.
Questions and doubt:
1)If i configure all switches  in transparent mode in order to create PVLAN, how can i manage normal vlan? For example if i would like to rename a normal VLAN i need to configure all single switches? I mean can i have PVLAN e VTP at the same time? (i know that VTP v3 support PVLAN, but for VTPv1 and v2?)
2)I have doubt on the task "Configuring trunk": i have to use private vlan trunks or "traditional trunks" (i mean trunk as if i have normal vlan)?
Thanks, Fabio
Hi Fabio,
Alright. In this case, if PC1 and PC3 are supposed to be isolated from each other and no other requirements are given, the task could be solved by creating a primary PVLAN and associating it with a single secondary isolated PVLAN. Both PCs shall be then placed into this isolated secondary PVLAN. They will be prevented from talking to each other but if the server (or whatever that is) connected to a PVLAN promisc port, they will be allowed to communicate with it.
may be in the future you can answer to some other questions!!!
Me or somebody else here. You are always welcome here on there forums. There are many outstanding networking experts here - I am sure you will always get a good response.
Best regards,
Peter
Peter Paluch
Hi Fabio,
I believe there is a typo in your task assignment. You are stating that "PC3 cannot communicate with PC3". What is the correct statement please? This detail may somewhat change the assignment solution.
No, you do not need private VLAN trunks. PVLAN trunks are special kinds of trunks which are necessary only in special scenarios. For more information, have a look at this thread: https://supportforums.cisco.com/message/3160548#3160548
Your solution would be to use normal trunks as usual, even if you are using PVLANs.
If you configure all switches to VTP Transparent mode then all changes to VLAN settings must be done manually. It does not matter whether you are modifying a normal VLAN or a private VLAN. It's as simple as that. VTPv1 and VTPv2 do not understand what a private VLAN is and cannot distribute information about the private VLANs, their types and mutual association (primary/secondary). Therefore, if you want to use PVLANs, you have to use the Transparent mode, and when you do that, you have to maintain your entire VLAN configuration manually.
VTPv3, as you have correctly pointed out, is capable of carrying information about PVLANs so it is strongly recommended to use that if possible. It has also another enhancements making it, say, more foolproof
vlan)?
Use traditional trunks, and have a look at the thread I have referenced for more information about what the private VLAN trunks are good for.
Best regards,
Peter
Hi Peter,
yes a made a mistake, request 1 and 2 were:
2) PC3 cannot communicate with PC1
Your response satisfied all my doubt.
I cannot implement this topolgy in real lab (i have not access to real lab), and also in GNS3 ore packet Tracer was not able to try it.
However, thanks for your help, may be in the future you can answer to some other questions!!!
  regardsFabio
Hi Fabio,
Best regards,
Peter
