11-05-2012 08:41 PM - edited 03-07-2019 09:52 AM
are PVST+ and Rapid PVST+ compatible, do they interoperate ?
with root bridges running PVST+ and new distribution switches running Rapid PVST+ - will this setup work ?
Solved! Go to Solution.
11-05-2012 08:47 PM
Rapid-PVST+ uses the same BPDU format as the 802.1D and it is backward compatible. It is difficult to convert all the switches in the enterprise network at the same time to rapid-PVST+. Because of the backward compatibility, you can convert phase by phase. It is recommended to implement the changes in the scheduled maintenance window.
You can run the LAN in mixed mode, such as a few switches in PVST+ and a few switches in rapid-PVST+ mode. In mixed mode, you do not receive the complete advantages of rapid-PVST+. The overall convergence time is the same as the convergence time of PVST+ mode. In order to take full advantage of rapid-PVST+, all the switches in the spanning tree topology must run the rapid-PVST+ .
Please rate helpful reply.
11-05-2012 08:47 PM
11-05-2012 08:55 PM
Thanks Abzal.
