PVST with do1q encapsulation?????
azmath.hk
our switch has been configured PVST with dot1q encapsulation on trunk port....
Since PVST is incampatable with dot1q encapsulation, how this switch has been working from long time?
Please need your valuable inputs...
Khan.
21 Replies 21
azmath.hk
waiting for your valuable comments
devang_etcom
Level 7
Level 7
Devang,
It does not talk about PVST with dot1q...
My question is why PVST is working with dot1q trunk?
bjw
Level 4
Level 4
Khan,
If your referring to PVST+ in CAT0s/IOS, then it does work with Dot1Q.
Dot1Q is a trunking protocol encasulation, and just provides a common pipe for vlan traffic.
PVST+ is a spanning tree protocol that prevents L2 loops.
See the following ref:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b0670.shtml#PVST
I am using PVST not PVST+...
My question is why PVST is working with dot1q?
In our switch network someone by mistakenly configured PVST on a switch and on its trunk port is configured as a dot1q encapsulation...how come its layer 2 connectivity is up when PVST is incompatable with dot1q encapsulation
Khan.
Please help me undersand my previous question...
please
By chance, is there only 1 active vlan active on the switch?
switch> show vlan trunk
We have 3 vlans running on this switch..By the way switch model is 2950....I am confuse plase help me out..
the command you mentioned is not working on this switch..
On switches, PVST was enhanced to PVST+ as soon as Cisco supported 802.1Q. So you cannot be running PVST on dot1Q trunk, that is necessarily PVST+.
When you say that PVST is not compatible with 802.1Q, is it just a theoric question or do you have a particular problem you want to share with the group?
Francois
bjw
Level 4
Level 4
Can you post the output of your show spanning-tree command on the subject switch?
bjw
Level 4
Level 4
Are you on IOS or CATos, what is the CAToS/IOS version, what type of switch is it?
A show ver command output might help.
I have attached show spanning-tree and show runn output....please advice
here is the show version
System image file is "flash:/c2950-i6q4l2-mz.121-14.EA1a.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision H0) with 20710K bytes of mem
ory.
Processor board ID FOC0803W1T9
Last reset from system-reset
Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0F:23:96:8A:40
Motherboard assembly number: 73-7280-05
Power supply part number: 34-0965-01
Motherboard serial number: FOC08032979
Power supply serial number: DAB08020HAX
Model revision number: H0
Motherboard revision number: A0
Model number: WS-C2950G-24-EI
System serial number: FOC0803W1T9
Configuration register is 0xF
