q-in-q tunnel on cisco nexus N9KC92304QC
BenyAben
looks like dot1q tunnel is not supported on nexus model C92304 QC. But will it work to pass double tagged vlan frames? Looks like its not working. Im wondering if there is a configuration to configure on nexus switch to pass double tagged vlan frames.
thank you,
6 Replies 6
BenyAben
Actually dot1q tunnel is configured on other switches and looks like this nexus switch is not passing the frames if I use two vlan tags.
I saw this  link, but Im not configuring dot1tunnel on this switch.
Thank you very much
So should I do anything on nexus switch
N9KC92304QC to be able to pass the double tagged frames?
so if I cant configure dot1qtunnel on the ports on this switch, can I at least pass double tagged vlan frames through this switch?
Thank you
then what are you doing ?
BB
the dot1q tunnel is terminating on another switch and the nexus switch N9KC92304QC is in the path to the remote switch where the other endpoint dot1q tunnel is configured. So the question is if nexus N9KC92304QC can pass double tagged frames? or we have to replace the switch? thank you
