03-01-2016 06:45 AM - edited 03-08-2019 04:47 AM
Hi All
Quick Q as feature navigator is a bit wooly on this ... are there are switches in the 2960X/XR range that support QinQ (ie: switchport mode dot1q-tunnel) and work ?
Ta
03-01-2016 07:21 AM
Hi Chris,
I just found the config guide for 2960 XR so it should be supported
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/software/15-0_2_EX1/vlan/configuration_guide/b_vlan_152ex1_2960-xr_cg/b_vlan_152ex1_2960-xr_cg_chapter_0111.html
Madhu
03-01-2016 07:26 AM
Thanks for coming back - yes this is what I've also read but have been told by a gold partner this only available on the 3560X upwards
May hit C-NSP for a finite answer
Chris
03-01-2016 09:26 AM
Sure, since we have a Config guide, i would say YES to this.
I don't have a box with me to check now.
Madhu
01-08-2017 09:13 PM
My HTE told that:
- QinQ is not supported on 2960X .
- On 2960XR (iplite license) we support traditional QinQ but do not support selective QinQ.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/54sg/configuration/guide/config/tunnel.html
