QOS and Bandwidth
Can you please tell me how to know the maximum processing capacity bandwidth with setting up a management QOS :
Catalyste 4510 R +E
Catalyst 3750
Routeur C1841
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
re: 4510 with what sup and line cards?
re: 3750, which exact model? stacked?  If stacked, how many units (and which models)?
re: 1841 is rated at 75 KPPS with minimum size Ethernet, capacity will increase with larger packets but decrease based on interaction of traffic and configuration
re: 4510 : : WS-C4510R+E   (WS-X45-SUP7-E)  with module : WS-X4648-RJ45-E
re 3750 (1):  stacked :
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS          12.2(53)SE2           C3750-IPSERVICESK9-M
     2 28    WS-C3750G-24TS-1U    12.2(53)SE2           C3750-IPSERVICESK9-M
     3 52    WS-C3750V2-48TS        12.2(53)SE2           C3750-IPSERVICESK9-M
     4 26    WS-C3750-24FS             12.2(53)SE2           C3750-IPSERVICESK9-M
re 3750 (2):  stacked :
*    1 26    WS-C3750-24FS      12.2(44)SE2           C3750-IPSERVICESK9-M
     2 26    WS-C3750-24TS      12.2(44)SE2           C3750-IPSERVICESK9-M
Thank you to tell me how I can know the maximum processing capacity bandwidth with setting up a management QOS for :
thanks
isclaimer
Posting
BTW, you can usually answer these type of questions by searching through the device datasheets, and it you're not used to doing that, it's a worthwhile skill to develop, especially helpful when comparing different devices.
In any case, your sup7e has a fabric bandwidth of 848 Gbps and 250 Mpps.  That sup, with the +E chassis supports 48 Gbps to line cards.  However, your 46xx line cards only support 24 Gbps to the fabric.
Your 3750s are the original architecture.  They all have a 32 Gbps fabric, and a maximum forwarding rate of 38.7 Mpps.  (24 gig port, or 48 FE port models may show a lower max PPS because all their ports, together, have a lessor PPS need.)  Original architecture 3750s have StackWise ports, noted as 32 Gbps (which I believe are dual 8 Gbps [duplex]).  Also note, with StackWise, all traffic between 3750 ports is placed on the stack ring, even between two ports on the same stack member.
