QoS buffer tuning
DONALD HEERING
Visitor
On the 3560 and 3750 switches, you can tune the buffer allocation between queues with the:
mls qos queue-set output <qset-id> buffers <alloc1> <alloc2> <alloc3> <alloc4>
command. The alloc numbers are percentages and not absolute values.
I've searched high and low looking for the size of the (absolute) total buffer space on the 3560, but I have not been able to find it.
I would guess this buffer size is the output queue size of the interface, which you can tune with the hold-queue out <size> command? It defaults to 40 frames, if I'm not mistaken.
Anyway got experience with this?
Best regards,
Donald Heering.
Hieu Cao
Level 7
Level 7
Donald,
You won't find the absolute values because they're not there, and those values are only percentages.
There are 4 egress queues with 3 threshold values per switch port. From the mls qos statement above, yes, the buffer is set at certain percentages for 4 egress queue in a particular port using the qset-id number.
In order for the switchport to work properly using the mls qos statement above, you would need to assign your switch port a particular qset-id.
Take a look at this document for more info.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml
HTH,
hieu
Hello Hieu,
Thanks! Useful document.
Still, there must be a limitation of memory available for the 4 egress queues somewhere :-). It seems on of the best kept secrets about the 3560...
Best regards,
Donald.
