QoS Config on Ehternet interface
cisco
i have a Layer3 1 gig ethernet interface on to which a 10Mb link has been terminated, i would like to configure QoS on the interface so that whenever the utilization reaches 10Mb it started shaping trafic. Please help
regards
Neo
5 Replies 5
Jon Marshall
regards
Neo
Neo
It would help to know which device you are working with. Be aware that the vast majority of Catalyst switches do not support shaping but there are perhaps other ways to limit the bandwidth. Need to know the device.
Jon
    Its a 4507 switch.
regards
Neo
Neo,
I'm sure Jon will provide you a better solution but the config below is taken from C4500 with shaping enable.
This example below is from C4500 (IOS 12.2(53)SG ) shows how to configure class-level, average-rate shaping. It limits traffic class class1 to a data transmission rate of 256 kbps:
Switch# configure terminal
Switch(config)# policy-map policy1
Switch(config-pmap)# class class1
Switch(config-pmap-c)# shape average 256000
Switch(config-pmap-c)# exit
Switch(config-pmap)# exit
Switch(config)# interface gigabitethernet1/1
Switch(config-if)# service-policy output policy1
Switch(config-if)# end
Switch# show policy-map policy1
  Policy Map policy1
    Class class1
Francisco
see http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/40sg/configuration/guide/qos.html
John Blakley
I'm not sure I understand your question. Are you saying that you have a 10Mb connection connected into your 1Gb port on the switch? If that's the case, you wouldn't need to shape it back to 10Mb because it would only get 10Mb anyway....
Sorry if I misunderstood....
John
HTH, John *** Please rate all useful posts ***
hi john,
             but when i do "sh interface " it shows that traffic is going above 10Mb.thats why i want to apply QoS.
regards
Neo
