3560 Inter vlan
psaravanan
Level 3
Level 3
Hi friends,
i am saravanan from Bangalore. I have one cisco 3560 switch and some L2 switches also.
i want to create inter vlan routing in the 3560. I already tried to enable ip routing command.
Then i tried to create routing protocol also.
so please give a valuable solution. IOS version is 12.2 (3560)
8 Replies 8
Jon Marshall
psaravanan wrote:
Hi friends,
Saravanan
What IOS feature set are you running and which routing protocol are you trying to use ?
To get the feature set run a "sh version" on the switch.
Jon
Leo Laohoo
pnicolette
Level 4
Level 4
One way is to create an interface for each vlan (they don't exist automatically), and give each interface an IP on the correct subnet.
My example:
VLAN 2 uses 10.1.2.0/24
VLAN 3 uses 10.1.3.0/24
ip routing
interface vlan 2
  no shutdown
  ip address 10.1.2.1 255.255.255.0
interface vlan 3
  no shutdown
  ip address 10.1.3.1 255.255.255.0
Unless I've forgotten something, hosts can now be configured to use the 3560's IP on their subnet/vlan as the default gateway.  They will then be able to reach devices on the other subnet/vlan.
Paul
P.S.  Another way (with a more complex scenario) is described at http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
vvasisth
Level 6
Level 6
there are 2 types of IOS images SMI and EMI
on SMI images you can only run intervlan routing and RIp
on the other hand EMI you can all other routing protocals like EGIRP , OSPF etc..
i am not sure what IOS you have but for inter vlan routing you just need to assign IP to diff vlans and enable routing by "ip routing " command.
Hope that helps.
Varun
Thanks for ur reply,
I am using c3560-ipbase-mz.122-25.SEB4.bin image. I enclose my configuration.
Conf:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CentralSwitch
enable secret 5 $1$Ir96$diD5JCZAF/uZZAxUnWsSw.
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode rapid-pvst
spanning-tree logging
no spanning-tree vlan 1
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/21
switchport access vlan 2
switchport mode access
interface GigabitEthernet0/24
interface GigabitEthernet0/25
switchport mode trunk
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 200.0.0.213 255.255.240.0
interface Vlan2
ip address 192.168.10.1 255.255.255.0
router rip
network 192.168.10.0
network 200.0.0.0
ip default-gateway 200.0.0.10
ip classless
ip http server
till routing between vlan1 to vlan 2 is not able to ping.
If you remover RIP config also it should work fine.
Did you check the default garteway on the PC ? it should be the vlan ip of there respective vlans
just to eliminate an pc related issues on the switch try this
ping 192.168.10.1 source vlan1
if it pings this means intervaln routing is working fine
Let me know the results.
regards,
varun
i already removed rip protocol and put default gateway as vlan 2 ip of my vlan 2 network. Then i can able to ping my default gateway (vlan2), but when i try to ping vlan 1 then request time out came.
Is there any option to put static routing.
I have the same problem .. InterVlan is not working even though i typed "IP ROUTING" in the global config mode.
Could someone help?
