QOS for 3560 access switch
gscalia01
   Pleae help
we have a class based qos scheme (see attached file) on our 4500 series access switches and we have a access 3560-48 switch runing IOS  Version 12.2(44)SE3 my question is can I use the same QOS scheme for the 3560 switch?
Tanks,
Jack
Reza Sharifi
The commands may not be exactly the same, but the IOS for 3560 supports class based Qos.
here is the config guide for Qos"
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swqos.html#wp1703072
Reza,
will enabling auto QOS on the swith be just as good?
thanks,
Jack.
Jack,
Yes, for VoIP Qos parameters, Auto Qos with configure it for you automatically
Have a look at the command reference guide for the policy-map auto Qos will configure for you.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_55_se/command/reference/cli1.html#wp13658183
