QoS help! Control traffic still being starved out despite QoS policy
vincehgov
Hi, I've configured a CBWFQ policy with Priority queue for voice traffic.  The problem I'm having is that when a user downloads a giant file over the link via HTTP or Cifs, EIGRP appears to be starved out and that effectively brings the link down.
Could you all look at my config to tell me where the problem might be?
This is a 4 meg ethernet handoff from the provider (Cox) between Irvine and London.
Class-maps to classify incoming traffic:
Extended IP access list CUVAVideo
    10 permit udp any eq 5445 any (9245939 matches)
    20 permit udp any any eq 5445 (4504 matches)
Extended IP access list FromCitrixServers
    10 permit ip host 10.40.112.107 any (43886238 matches)
    20 permit ip host 10.40.112.108 any (108997111 matches)
    30 permit ip host 10.40.112.43 any (4165954 matches)
    40 permit ip host 10.40.112.46 any (4090879 matches)
    50 deny ip any any (555133236 matches)
Class Map match-any class-default (id 0)
   Match any
Class Map match-any RTP-Video (id 5)
   Match protocol rtp video
   Match access-group name CUVAVideo
Class Map match-any Priority (id 6)
   Match protocol rtp audio
Class Map match-any Control (id 7)
   Match protocol mgcp
   Match protocol skinny
   Match protocol h323
   Match protocol sip
   Match protocol icmp
   Match protocol eigrp
   Match protocol ospf
   Match protocol snmp
Class Map match-any Interactive (id 8)
   Match protocol citrix
   Match protocol telnet
   Match protocol ssh
   Match access-group name FromCitrixServers
Policy-map to classify incoming traffic:
  Policy Map To_WAN
    Class Priority
      set dscp ef
    Class Control
      set dscp af41
    Class RTP-Video
      set dscp af31
    Class Interactive
      set dscp af21
    Class class-default
      set dscp default
Class-maps to enforce policy on outgoing traffic:
Extended IP access list WAN-Control
    10 permit udp any any eq ntp (18848 matches)
    20 permit udp any eq ntp any
    30 permit eigrp any any (1174234 matches)
Class Map match-any AF41 (id 1)
   Match   dscp af41 (34)
   Match access-group name WAN-Control
Class Map match-any EF (id 2)
   Match   dscp ef (46)
Class Map match-any AF21 (id 3)
   Match   dscp af21 (18)
Class Map match-any AF31 (id 4)
   Match   dscp af31 (26)
   Match any
Policy-map to enforce policy on outgoing traffic (with shaping):
  Policy Map To_UK_Shaper
    Class class-default
      Average Rate Traffic Shaping
      cir 4000000 (bps)
      service-policy To_UK
  Policy Map To_UK
    Class EF
      priority 512 (kbps)
    Class AF41
      bandwidth 256 (kbps)
    Class AF31
      bandwidth 768 (kbps)
    Class AF21
      bandwidth 1024 (kbps)
    Class class-default
Applied on outgoing interface:
interface FastEthernet0/0/0
description to UK via Cox TLC
bandwidth 4000
ip address 192.168.41.40 255.255.255.0
duplex full
speed 10
service-policy output To_UK_Shaper
end
Here is the sh policy-map for the interface:
I don't know why there are so many drops for AF21.  I don't see any drops for AF41.  Would anyone go about a different way of doing this?  I'd like to see some examples from you experts.
#sh policy-map int fa 0/0/0
FastEthernet0/0/0
  Service-policy output: To_UK_Shaper
    Class-map: class-default (match-any)
      31135173 packets, 8815650918 bytes
      5 minute offered rate 3446000 bps, drop rate 27000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/33765/0
      (pkts output/bytes output) 31101409/8809555924
      shape (average) cir 4000000, bc 16000, be 16000
      target shape rate 4000000
      Service-policy : To_UK
        queue stats for all priority classes:
          Queueing
          (queue depth/total drops/no-buffer drops) 0/17/0
          (pkts output/bytes output) 5694740/1295714435
        Class-map: EF (match-any)
          5694757 packets, 1295732084 bytes
          5 minute offered rate 87000 bps, drop rate 0 bps
          Match:  dscp ef (46)
            5 minute rate 87000 bps
          Priority: 512 kbps, burst bytes 12800, b/w exceed drops: 17
        Class-map: AF41 (match-any)
          2039678 packets, 171167811 bytes
          5 minute offered rate 2000 bps, drop rate 0 bps
          Match:  dscp af41 (34)
            1928499 packets, 166099509 bytes
            5 minute rate 2000 bps
          Match: access-group name WAN-Control
            111179 packets, 5068302 bytes
            5 minute rate 0 bps
          Queueing
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 2039678/174463657
          bandwidth 256 kbps
        Class-map: AF31 (match-any)
          2438468 packets, 1514221844 bytes
          5 minute offered rate 180000 bps, drop rate 0 bps
          Match:  dscp af31 (26)
            5 minute rate 180000 bps
          Queueing
          (pkts output/bytes output) 2438468/1514219989
          bandwidth 768 kbps
        Class-map: AF21 (match-any)
          11029034 packets, 2904495680 bytes
          5 minute offered rate 150000 bps, drop rate 0 bps
          Match:  dscp af21 (18)
            11029033 packets, 2904495680 bytes
            5 minute rate 150000 bps
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1565/0
          (pkts output/bytes output) 11027469/2903202927
          bandwidth 1024 kbps
          9933237 packets, 2930033884 bytes
          5 minute offered rate 3060000 bps, drop rate 27000 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops) 0/32183/0
          (pkts output/bytes output) 9901054/2921954916
          bandwidth 256 kbps
dominic.caron
Level 5
Level 5
The one dropping the eigrp packets is the provider, not you. QOS will not help if it's applied on your side.
dominic.caron
Level 5
Level 5
Hi Dominic,
Thank you for your response.  How did you come to that conclusion?  So you're saying that despite the policing policy, the provider still might be dropping our packets?  We have a 4 meg line from them.  Should I calculate for something lower to minimize the risk that they'll drop our packets?
Vince
I lowered my shaping to 3.8 Mbps and now I'm getting more predictible results.
Thanks.
