QOS Issue 3650E to 2811 via Metro E Handoff
I have an issue where the QOS on the 3560 is not working or reporting correctly.
The setup is
1) Remote site 2811 with Metro Ethernet Handoff. (Access lists contain standard voice, voice signaling and video ports and ip addresses and these access lists are identical on both devices) Metro Ethernet is provided to us via a standard CAT6 from the Metro E controlled switch.
class-map match-all priority-data
match access-group 103
class-map match-all voice-video-traffic
match access-group 102
policy-map QOS-POLICY
class voice-video-traffic
priority percent 50
set dscp ef
class priority-data
bandwidth percent 20
set dscp af31
class class-default
fair-queue
random-detect
interface FastEthernet0/1
description Connection to Metro Ethernet
ip address 10.254.254.2 255.255.255.252
service-policy output QOS-POLICY
! << just showing voice and video class here>>
sh policy-map interface
FastEthernet0/1
Service-policy output: QOS-POLICY
Class-map: voice-video-traffic (match-all)
14142 packets, 3711515 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 102
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 50 (%)
Bandwidth 5000 (kbps) Burst 125000 (Bytes)
(pkts matched/bytes matched) 7/1042
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 14142
2) Corporate 3560E has mls qos configured.
police 5000000 80000 exceed-action policed-dscp-transmit
set dscp ef
class priority-data
set dscp af31
police 2000000 40000 exceed-action policed-dscp-transmit
class class-default
no switchport
ip address 10.254.254.1 255.255.255.252
mls qos trust dscp
service-policy input QOS-POLICY
FastEthernet0/1
Service-policy input: QOS-POLICY
0 packets, 0 bytes
Class-map: priority-data (match-all)
0 packets, 0 bytes
Match: access-group 103
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Any ideas on what I am missing?
Edison Ortiz
You aren't missing anything.
show policy-map interface will display software counters. QoS is done in hardware and in order to view statistics, you need hardware related commands.
show mls qos interface stat is what you need.
adamclarkuk_2
Level 4
Level 4
Can you define not working correctly?
* Sorry ignore that, I see what you mean :-s
Edison Ortiz
