Loopback addresses
Kevin Melton
Level 2
Level 2
Is it ever possible to assign loopback addresses on Cisco Switches. Or are they only configurable on routers?
Kevin
adamclarkuk_2
Level 4
Level 4
You can assign loopback addresses to some layer 3 swtiches such as the 6500/3560, which switch are trying to use loopbacks on?
Edison Ortiz
As indicated by Amit and Adam, you are able to configure loopback interfaces on Cisco switches that are capable to run Layer3 services.
It seems your question is more inclined towards Layer2 switches such as 2960. For Layer2 switches, the answer is no.
For layer2 switches, I recommend configuring a switch virtual interface and assign an IP address to it for managing purposes.
Creating a loopback on such switch won't provide reachability to/from the loopback as the switch can't route.
Edison.
