QoS issue on 3750
afredriksson
Hi all,
I have a QoS issue with a cisco 3750-stack (2 x WS-C3750-24TS, 12.2(53)SE).
We have some PBX- and Web systems connected via trunks to GE-ports and service providers (MPLS based IP-VPN) connected to FE-ports. Traffic rate on most ports are very low, approx. 1-3 Mbit/s.
One SP port connects many sites so that port tends to hover around 10Mbit/s, of which most traffic is VoIP using DSCP40/46. That port is now dropping traffic.
The QoS configuration is generated long ago using “Auto-Qos” and have worked fine for years, but now when one port tends to go above 10Mbit/s, VoIP packets gets dropped.
Short term solution is to turn off QoS (no mls qos) but that might open another box of problems...
Any suggestions on how to increase RTP flow (out Q1T3) and “allow” up to about 20% (20 Mbit/s) VoIP traffic on SP links?
QoS Config:
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 60 40
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 40 10 20 30
SP Interface config:
interface FastEthernet1/0/19
 description xxx
 switchport trunk native vlan x
 switchport trunk allowed vlan x,x,x
 switchport mode trunk
 srr-queue bandwidth share 10 10 60 20
 mls qos trust dscp
 spanning-tree portfast
I have tried using:
srr-queue bandwidth share 30 10 20 40
queue-set 2
Result: Worse (Tried with and without queue-set 2)
sh mls qos int fa 1/0/19 statistics:
FastEthernet1/0/19 (All statistics are in packets)
  dscp: incoming
  0 -  4 :     3460743            0            0            0            0
  5 -  9 :           0            0            0       181282            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0       134758
 25 - 29 :           0           99            0            0            0
 30 - 34 :           0            0            0            0         8227
 35 - 39 :           0            0            0            0            0
 40 - 44 :     6835905            0            0            0            0
 45 - 49 :           0       436411            0        16060            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0         1653            0            0            0
 60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :      204275            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0       177984
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0        20758
 35 - 39 :           0            0            0            0            0
 40 - 44 :     9603319            0            0            0            0
 45 - 49 :           0       617236            0         2257            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :    11078474            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :    10431109            0            0         8766          613
  5 -  7 :      183165         2176            0
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           0           0      183165
 queue 1:           0        4619       11357
 queue 2:           0           0         613
 queue 3:           0           0    10434914
  output queues dropped:
 queue 0:           0           0      113326
 queue 1:           0           0           0
 queue 2:           0           0           0
 queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Anders
acampbell
Hi Anders,
A very important command is missing from your interface when you use QOS.
Int fas 1/0/19
priority-queue out
All four queues participate in the SRR unless the priority queue is enabled, in which case the first bandwidth weight is ignored and is not used in the ratio calculation. Priority queue is serviced until empty before the other queues are serviced. You enable the priority queue by using the priority-queue out interface configuration command.
Alex
Regards, Alex. Please rate useful posts.
acampbell
Hi Anders,
Int fas 1/0/19
priority-queue out
Alex
