QoS marking question
dahua.huang
Hi, all QoS experts
I have a question about QoS.
Distribution Switch A is a L3 switch for vlan 200 and a inter G1/1 downlink  to Access Layer Switch B G0/25
what is the correct way to put service-policy input?
Distribton Switch - A
interface G1/1
des link to Access layer switch B
mls qos trust dscp
interface vlan 200
ip address x.x.x.x
service-policy input QOS ????
# Should I put a policy here,
Access Layer Switch - B
interface G0/25
des uplink to Distribution layer switch A
mls qos trust dscp
interface range g0/1 - 24
mls qos vlan-based
interface vlan 200
Here is my question:
Do I need put service-policy into distribution layer vlan interface? ( this switche designed for L3 only, and around 60 L3 vlan interface inside )
If yes, does the packets will be market again and again through the vlans?
Thanks a lot.
5 Replies 5
hello Dahua,
What is the gateway of the User end stations is it going to be access or distribution. I assume that is the distribution switch and in that case there is no point in having service policy in vlan 200 in access switch
regards
Harish.
then we have another problem.
our distribution is 6509 with sup720-10G.
it has too many vlans inside and it will cause tcam exceed limited if I put service-policy in all.
Any good way to reduce it?
Hi there,
Remember that apply a service policy on the svi is not possible on all the platforms (for example 3550 and older can't). By the rest, assuming your platform has at least the same capabilities than a 3560, you can apply a policy there.
Hth
Alessio
Pronoy Dasgupta
Hello Dahua,
I am interestedin finding out the intent of using the service policy. Are you simply trying to mark some sort of traffic or police / markdown other traffic? The placement of the service policy to some extent might depend on what the desired action is. Also, the input service policy can be placed on the physical interface itself on a 6500. It does not need to be placed specifically on an interface vlan. That limitation comes into the picture when you are trying to configure an out-bound service policy.
If you let us know what the configuration of the service policy would look like, maybe we can help you further.
PD
Hi, Pronoy Gupta
Thanks first
Here is our QoS template.
class-map match-any VoIP
description Voice IP Phone RTP
match access-group 162
class-map match-any Signaling
description SCCP (skinny) signaling
match access-group 166
class-map match-any BACKUP
description Generic TSM, NFS
match access-group 169
policy-map QOS
class VoIP
   set dscp ef
class Signaling
   set dscp cs3
class BACKUP
   set dscp af11
class class-default
set dscp default
access-list 162 remark * VoIP class (IP Precedence 5)
access-list 162 remark *** UDP 16384-32767 IP Conference Video & Audio Stream ***
access-list 162 permit udp any gt 16384 any range 16384 32767
access-list 162 permit udp any range 16384 32767 any gt 16384
interface config in 6509 Distrition layer:
int range g1/1 - 48
description 1P3Q8T
wrr-queue bandwidth 255 120 40
wrr-queue queue-limit 100 100 100
wrr-queue random-detect min-threshold 1 70 70 70 70 70 70 80 90
wrr-queue random-detect min-threshold 2 70 70 70 70 70 70 80 90
wrr-queue random-detect min-threshold 3 70 70 70 70 70 70 80 90
wrr-queue cos-map 1 6 0
wrr-queue cos-map 1 7 1
wrr-queue cos-map 1 8 2
wrr-queue cos-map 2 7 3
wrr-queue cos-map 2 8 4
wrr-queue cos-map 3 7 6
wrr-queue cos-map 3 8 7
mls qos trust dscp
same for mod 2 - 8 (all the inferface are connected to L2 Access Layer switches, such as 3750 or 4507.)
interface vlan xxx
ip address x.x.x.x
standby 0 ip x.x.x.x
We have over 90 vlan interfaces in each 6509. only put service-policy into 35 vlans. and it take  64% of TCAM already. it will shows tcam exceed limited if over 60 vlans with service-policy.
Config in access-layer
Class-map
Policy-map
ACL
interface G0/25
des uplink to Distribution layer A
mls qos trust dscp
interface G0/26
des uplink to Distribution layer B
mls qos trust dscp
srr-queue bandwidth share 8 30 60 2
srr-queue bandwidth shape 0 0 0 0
priority-queue out
mls qos vlan-based
interface vlan 200
6509#show mod
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL1432PYL8
  2   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL1432PYJW
  3    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1431P87P
  4    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1431P8C2
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1426LQ6M
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1431P7TS
  8   24  SFM-capable 24-port 100FX Multi mode   WS-X6524-100FX-MM  SAL085283ZD
  9   10  WiSM WLAN Service Module               WS-SVC-WISM-1-K9   SAL1442WSBG
#show tcam counts
           Used        Free        Percent Used       Reserved
Labels:(in) 49        4023            1                    24
Labels:(eg)  0        4072            0                    24
ACL_TCAM
  Masks:    100        3996            2                    72
Entries:    150       32618            0                   576
QOS_TCAM
  Masks:   2644        1452           64                    25
Entries:   9965       22803           30                   200
    LOU:     19         109           14
  ANDOR:      0          16            0
  ORAND:      0          16            0
    ADJ:      4        2044            0
#show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI6, RELEASE SOFTWARE (fc4)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 28-Mar-11 12:09 by prod_rel_team
