06-20-2015 12:08 AM - edited 03-08-2019 12:38 AM
Hi, I need to classify traffic based on Vlan ID, but I don't find "match vlan id" under a class-map.
Configuration guide tell me this, but I cannot find the way to configure ACL in order to match Vlan ID:
match Commands | Direction | Match Criteria |
match access-group {access_list_number | nameaccess_list_name} | Both | Access control list (ACL). Note Use ACLs to match the following: |
Can you help me?
Marco
06-20-2015 04:26 AM
Macro,
U can use vacl.
Hth
Inayath
06-20-2015 09:15 AM
The note on right side of your post says, use ACL to match VLAN ID.
