QoS on Cisco 871 does not work, please help!
Alen Danielyan
I am trying to make QoS on my Cisco 871 and 870 routers. They are installed in branches and connected via 2 DM-VPN channels each with head office.
I am trying to set up QoS, but it seems it does not work. Here is my config on the branch routers:
First of all I am marking my traffic:
ip access-list extended VoIPT
remark VoIP Traffic
permit udp host 192.168.0.253 any
permit udp any host 192.168.0.253
permit udp host 192.168.30.253 any
permit udp any host 192.168.30.253
deny ip any any
ip access-list extended HighPT
remark Traffic to regional center 1 Oracle servers (subnet 192.168.0.0) and reverse
permit tcp 192.168.0.0 0.0.63.255 192.168.0.0 0.0.0.255 eq 1521
permit tcp 192.168.0.0 0.0.0.255 eq 1521 192.168.0.0 0.0.63.255
remark Traffic to regional center 2 Oracle servers (subnet 192.168.30.0) and reverse
permit tcp 192.168.0.0 0.0.63.255 192.168.30.0 0.0.0.255 eq 1521
permit tcp 192.168.30.0 0.0.0.255 eq 1521 192.168.0.0 0.0.63.255
deny ip any any
ip access-list extended LowPT
remark SMB Traffic (direct and reverse)
permit tcp any any eq 445
permit tcp any eq 445 any
permit udp any any eq 445
permit udp any eq 445 any
remark Lotus Notes Traffic (direct and reverse)
permit tcp any any eq 1352
permit tcp any eq 1352 any
remark e-mail Traffic (direct and reverse)
permit tcp any any eq smtp
permit tcp any eq smtp any
permit tcp any any eq pop3
permit tcp any eq pop3 any
deny ip any any
class-map DSCP-VoIPT
match access-group name VoIPT
exit
class-map DSCP-HighPT
match access-group name HighPT
exit
class-map DSCP-LowPT
match access-group name LowPT
exit
policy-map MyDSCP
class DSCP-VoIPT
set DSCP ef
exit
class DSCP-HighPT
set DSCP af31
exit
class class-default
set DSCP cs1
exit
class DSCP-LowPT
set DSCP default
exit
                        interface fa0
service-policy input MyDSCP
Second step - QoS:
class-map QoS-VoIPT
match ip dscp ef
exit
class-map QoS-HighPT
match ip dscp af31
exit
class-map QoS-LowPT
match ip dscp default
exit
policy-map MyQoS
class QoS-VoIPT
priority percent 38
exit
class QoS-HighPT
bandwidth percent 25
exit
class class-default
fair-queue
exit
class QoS-LowPT
bandwidth percent 10
exit
policy-map ParentQoS4DMVPN
class class-default
shape average 1900000
service-policy MyQoS
exit
                  interface tunnel1
qos pre-classify
service-policy output ParentQoS4DMVPN
interface tunnel2
qos pre-classify
interface fa3
bandwidth 2000
interface fa4
bandwidth 2000
Nothing is working, even shaping is not working! I also tried to apply the policy to the physical interfaces - with the same result. Please show me my mistake.
P.S. IOS is 12.4(24)T2, adv. ip services.
28 Replies 28
Alen Danielyan
People, please help.
May be I should open this discussion in another section of the forum, tell me.
P.S. I mentioned a mistake in bandwidth command, it is counted in kbps, not bps, corrected.
Can you post output of  sh policy-map interface x/x, sh policy-map,  sh class-map and also sh access-list.
Regards.
Alain.
Dear cadetalain, thank you very much for your help.
Here is the required info (I made it during real traffic tranfer! For the tests conditions please see PS at the end):
branch#show policy-map int fa0
FastEthernet0
  Service-policy input: MyDSCP
    Class-map: DSCP-VoIPT (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name VoIPT
      QoS Set
        dscp ef
          Packets marked 0
    Class-map: DSCP-HighPT (match-all)
      0 packets, 0 bytes
      Match: access-group name HighPT
      QoS Set
        dscp af31
          Packets marked 0
    Class-map: DSCP-LowPT (match-all)
      0 packets, 0 bytes
      Match: access-group name LowPT
      QoS Set
        dscp default
          Packets marked 0
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
      QoS Set
        dscp cs1
          Packets marked 0
So packets are not marked!?
branch#show policy-map int tun2
Tunnel2
  Service-policy output: ParentQoS4DMVPN
      536562 packets, 418567849 bytes
      5 minute offered rate 2658000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 731/131010
      shape (average) cir 1900000, bc 7600, be 7600
      target shape rate 1900000
      Service-policy : MyQoS
        queue stats for all priority classes:
          (pkts output/bytes output) 0/0
        Class-map: QoS-VoIPT (match-all)
          0 packets, 0 bytes
          Match: ip dscp ef (46)
          Priority: 38% (722 kbps), burst bytes 18050, b/w exceed drops: 0
        Class-map: QoS-HighPT (match-all)
          0 packets, 0 bytes
          Match: ip dscp af31 (26)
          Queueing
          bandwidth 25% (475 kbps)
        Class-map: QoS-LowPT (match-all)
          535823 packets, 418494629 bytes
          5 minute offered rate 2660000 bps, drop rate 0 bps
          Match: ip dscp default (0)
          Queueing
          bandwidth 10% (190 kbps)
          739 packets, 73220 bytes
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
          Fair-queue: per-flow queue limit 16
Very strange! I can see some traffic was guaranteed bandwidth as QoS-LowPT, although no marking was made. Besides something strange is with default class, I see packets count is not zero, but offered rate is zero!?
Branch#sh policy-map
  Policy Map CP_Policy_CEF-Exc
    Class class-default
     police cir 1000000 bc 31250
       conform-action transmit
       exceed-action drop
  Policy Map CP_Policy_Host
    Class cp_icmp
     police cir 50000 bc 1562
       exceed-action drop
    Class cp_isakmp
       exceed-action drop
    Class cp_esp
     police cir 5000000 bc 156250
       exceed-action drop
    Class cp_ssh
     police cir 20000 bc 1500
       exceed-action drop
    Class class-default
     police cir 10000 bc 1500
       exceed-action drop
  Policy Map ParentQoS4DMVPN
    Class class-default
      Average Rate Traffic Shaping
      cir 1900000 (bps)
  Policy Map MyDSCP
    Class DSCP-VoIPT
      set dscp ef
    Class DSCP-HighPT
      set dscp af31
    Class DSCP-LowPT
      set dscp default
    Class class-default
      set dscp cs1
  Policy Map MyQoS
    Class QoS-VoIPT
      priority 38 (%)
    Class QoS-HighPT
      bandwidth 25 (%)
    Class QoS-LowPT
      bandwidth 10 (%)
    Class class-default
      fair-queue
  Policy Map CP_Policy_Transit
    Class class-default
     police cir 10000000 bc 312500
       exceed-action drop
Branch#sh class-map
Class Map match-all DSCP-HighPT (id 6)
   Match access-group name HighPT
Class Map match-all QoS-LowPT (id 10)
   Match ip  dscp default (0)
Class Map match-all cp_ssh (id 1)
   Match access-group name cp_ssh
Class Map match-any class-default (id 0)
   Match any
Class Map match-all cp_esp (id 2)
   Match access-group name cp_esp
Class Map match-all QoS-VoIPT (id 8)
   Match ip  dscp ef (46)
Class Map match-all cp_isakmp (id 3)
   Match access-group name cp_isakmp
Class Map match-all cp_icmp (id 4)
   Match access-group name cp_icmp
Class Map match-all DSCP-VoIPT (id 5)
   Match access-group name VoIPT
Class Map match-all QoS-HighPT (id 9)
   Match ip  dscp af31 (26)
Class Map match-all DSCP-LowPT (id 7)
   Match access-group name LowPT
Branch#sh access-list
Standard IP access list 42
    10 permit 192.168.0.1
    20 deny   any
Extended IP access list HighPT
    10 permit tcp 192.168.0.0 0.0.63.255 192.168.0.0 0.0.0.255 eq 1521
    20 permit tcp 192.168.0.0 0.0.0.255 eq 1521 192.168.0.0 0.0.63.255
    30 permit tcp 192.168.0.0 0.0.63.255 192.168.30.0 0.0.0.255 eq 1521
    40 permit tcp 192.168.30.0 0.0.0.255 eq 1521 192.168.0.0 0.0.63.255
    50 deny ip any any
Extended IP access list LowPT
    10 permit tcp any any eq 445
    20 permit tcp any eq 445 any
    30 permit udp any any eq 445
    40 permit udp any eq 445 any
    50 permit tcp any any eq 1352
    60 permit tcp any eq 1352 any
    70 permit tcp any any eq smtp
    80 permit tcp any eq smtp any
    90 permit tcp any any eq pop3
    100 permit tcp any eq pop3 any
    110 deny ip any any
Extended IP access list VoIPT
    10 permit udp host 192.168.0.253 any
    20 permit udp any host 192.168.0.253
    30 permit udp host 192.168.30.253 any
    40 permit udp any host 192.168.30.253
    50 deny ip any any
Extended IP access list cp_esp
    10 permit esp any any
    20 deny ip any any
Extended IP access list cp_icmp
    10 permit icmp any any
    20 deny ip any any (651 matches)
Extended IP access list cp_isakmp
    10 permit udp any eq isakmp any eq isakmp (651 matches)
    20 deny ip any any
Extended IP access list cp_ssh
    10 permit tcp any any eq 22
    20 deny ip any any
Extended IP access list fa4_in
    10 permit tcp host 192.168.110.2 host 192.168.87.111 eq 22
    20 permit udp host 192.168.110.2 eq isakmp host 192.168.87.111 eq isakmp
    30 permit esp host 192.168.110.2 host 192.168.87.111
    40 permit icmp host 192.168.110.2 host 192.168.87.111
    50 deny ip any any
Extended IP access list sl_def_acl
    10 deny tcp any any eq telnet log
    20 deny tcp any any eq www log
    30 deny tcp any any eq 22 log
    40 permit tcp any any eq 22 log
Extended IP access list vlan1_in
    10 deny udp any any eq netbios-dgm
    20 deny udp any any eq netbios-ns
    30 deny udp any any eq netbios-ss
    40 deny tcp any any eq 139
    50 permit ip any any (734417 matches)
Extended IP access list vlan20_in
    10 permit tcp host x.y.69.33 host x.y.69.217 eq 22
    20 permit udp host x.y.69.33 eq isakmp host x.y.69.217 eq isakmp (664 matches)
    30 permit esp host x.y.69.33 host x.y.69.217 (851454 matches)
    40 permit icmp host x.y.69.33 host x.y.69.217
    50 deny ip any any
Interface FA0 - vlan 1 is LAN interface, FA3 - vlan 20 and FA4 - are WAN interfaces. For my tests FA3 is used.
I have 2 tunnels, 1 tunnel is used for tests.
BTW, why my access list cp_esp is not showing any packets?! My traffic is going via tunnel, everything except ICMP, ISAKMP, ESP and SSH are denied, but I have real traffic passing via routers, how is it possible? Is this an IOS glitch?
P.S. For my experiments I am using:
1. Hardware:
- one Cisco 1811 – with head office config
- one Cisco 871 just for routing (as ISP emulator)
- one Cisco 871 – with one of the branches config
- two PCs connected one to the branch router, another – to head office router.
There is GRE over IPSec AES 256 bit encrypted DM-VPN between the Head office and branches. The test routers are connected via VPN.
2. Software:
jPerf + file copying to check if policy works. In jPerf I can change protocol and port hence changing the traffic class.
Now, first of all I can see throughoutput ~6mbps full duplex, although I have control plane host policy with 5mbps restriction for ESP and shaping set on the Tunnel interface (I tried to apply it also on the physical interface instead either, with the same result). So even shaping doesn’t work!? (Shouldn’t it restrict the bandwidth even if there is free bandwidth?)
- Very strange! I can see some traffic was guaranteed bandwidth as QoS-LowPT, although no marking was made.
Well, later I understood that traffic is just matching the class and this is because the most part of traffic is initially having dscp default, which is the one I used for LowPT class. So this is clear.
So the main questions are:
- Why marking on LAN interface is not working?
- Why shaping on Tunnel (and also on physical) interface is not working?
- And why encrypted traffic is not matched by control plane policing class which matches ESP packets?
Are you marking the traffic on the LAN side?
Yes. I apply the marking policy to FE0, which is physical interface connected to LAN. Here is its settings:
interface FastEthernet0
description To_LAN
end
Can you post the full running please because it's weird you get no hits on class-map for fa0.
Regards.
Alain.
Regards.
Alain.
Sure. Here it is:
Branch#show run
Building configuration...
Current configuration : 9199 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Branch
boot-start-marker
boot system flash:c870-advipservicesk9-mz.124-24.T2.bin
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 12
logging message-counter syslog
logging buffered 131072 notifications
no logging console
no logging monitor
enable secret 5 $1$1a4K$gjj4DvMKXrhltQStNVS.H.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone AMT 4
clock summer-time AMST recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
no ip source-route
ip arp proxy disable
no ip gratuitous-arps
ip dhcp database flash:dhcp
no ip dhcp use vrf connected
ip dhcp bootp ignore
ip dhcp excluded-address 192.168.11.2 192.168.11.10
ip dhcp excluded-address 192.168.11.240 192.168.11.254
ip dhcp pool Shushi_pool
   network 192.168.11.0 255.255.255.0
   default-router 192.168.11.1
   lease 90
ip cef
no ip bootp server
no ip domain lookup
ip domain name ANet
login block-for 60 attempts 3 within 15
no ipv6 cef
username xxx secret 5 $1$kqnm$5f4OutOM529GELfZdVNkx/
username yyy secret 5 $1$Ieyz$m9mhGmTQKpIL9z57FTlp0.
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp key 6 zzz address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec security-association replay window-size 512
crypto ipsec transform-set dmvpnset esp-aes 256 esp-sha-hmac
crypto ipsec profile dmvpnprof
set transform-set dmvpnset
archive
log config
  logging enable
  logging size 900
  notify syslog contenttype plaintext
  hidekeys
path flash:Backed-up-Config
maximum 5
time-period 1440
class-map match-all DSCP-HighPT
class-map match-all QoS-LowPT
class-map match-all cp_ssh
match access-group name cp_ssh
class-map match-all cp_esp
match access-group name cp_esp
class-map match-all QoS-VoIPT
match ip dscp ef
class-map match-all cp_isakmp
match access-group name cp_isakmp
class-map match-all cp_icmp
match access-group name cp_icmp
class-map match-all DSCP-VoIPT
class-map match-all QoS-HighPT
match ip dscp af31
class-map match-all DSCP-LowPT
policy-map CP_Policy_CEF-Exc
class class-default
    police 1000000 conform-action transmit  exceed-action drop
policy-map CP_Policy_Host
class cp_icmp
    police 50000 conform-action transmit  exceed-action drop
class cp_isakmp
class cp_esp
    police 5000000 conform-action transmit  exceed-action drop
class cp_ssh
    police 20000 conform-action transmit  exceed-action drop
class class-default
    police 10000 conform-action transmit  exceed-action drop
policy-map MyQoS
class QoS-VoIPT
   priority percent 38
class QoS-HighPT
class QoS-LowPT
class class-default
    fair-queue
class class-default
policy-map MyDSCP
class DSCP-VoIPT
  set dscp ef
class DSCP-HighPT
  set dscp af31
class DSCP-LowPT
  set dscp default
class class-default
  set dscp cs1
policy-map CP_Policy_Transit
class class-default
    police 10000000 conform-action transmit  exceed-action drop
pseudowire-class TO_CORE
encapsulation l2tpv3
interworking ethernet
ip local interface Loopback0
interface Loopback0
ip address 192.168.98.11 255.255.255.255
interface Tunnel1
description DMVPN_FA4_To_Core_ISP1
ip address 192.168.97.6 255.255.255.0
ip mtu 1400
ip nhrp authentication dmvpn
ip nhrp map 192.168.97.1 192.168.110.2
ip nhrp network-id 1
ip nhrp nhs 192.168.97.1
ip tcp adjust-mss 1360
ip ospf network point-to-point
ip ospf cost 20
ip ospf hello-interval 3
ip ospf dead-interval 9
qos pre-classify
tunnel source FastEthernet4
tunnel destination 192.168.110.2
tunnel path-mtu-discovery
tunnel protection ipsec profile dmvpnprof
interface Tunnel2
description DMVPN_VLAN20_To_Core_ISP2
ip address 192.168.96.6 255.255.255.0
ip mtu 1400
ip nhrp map 192.168.96.1 x.y.69.33
ip nhrp network-id 2
ip nhrp nhs 192.168.96.1
ip ospf cost 10
qos pre-classify
tunnel source Vlan20
tunnel destination x.y.69.33
description To_LAN
interface FastEthernet1
description L2TP
switchport access vlan 55
interface FastEthernet2
interface FastEthernet3
description To_Core_ISP2
switchport access vlan 20
bandwidth 2000
interface FastEthernet4
description To_Core_ISP1
bandwidth 256
ip address 192.168.87.111 255.255.255.0
ip access-group fa4_in in
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface Vlan1
description To_LAN
ip address 192.168.11.1 255.255.255.0
ip access-group vlan1_in in
interface Vlan20
ip address x.y.69.217 255.255.255.192
ip access-group vlan20_in in
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan55
description L2TP
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.98.100 21 pw-class TO_CORE
router ospf 1
router-id 192.168.98.11
log-adjacency-changes
passive-interface default
no passive-interface Tunnel1
no passive-interface Tunnel2
network 192.168.11.0 0.0.0.255 area 0
network 192.168.96.0 0.0.0.255 area 0
network 192.168.97.0 0.0.0.255 area 0
network 192.168.98.11 0.0.0.0 area 0
ip forward-protocol nd
ip route 192.168.110.2 255.255.255.255 192.168.87.1
ip route x.y.69.33 255.255.255.255 x.y.69.225
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
deny   ip any any
deny   ip any any
remark VoIP Traffic
deny   ip any any
ip access-list extended cp_esp
permit esp any any
deny   ip any any
ip access-list extended cp_icmp
permit icmp any any
deny   ip any any
ip access-list extended cp_isakmp
deny   ip any any
ip access-list extended cp_ssh
deny   ip any any
ip access-list extended fa4_in
deny   ip any any
ip access-list extended vlan1_in
permit ip any any
ip access-list extended vlan20_in
deny   ip any any
logging trap notifications
logging facility local2
logging source-interface Loopback0
access-list 42 permit 192.168.0.1
access-list 42 deny   any
no cdp run
control-plane host
service-policy input CP_Policy_Host
control-plane transit
service-policy input CP_Policy_Transit
control-plane cef-exception
service-policy input CP_Policy_CEF-Exc
control-plane
line con 0
exec-timeout 5 0
no modem enable
transport output ssh
line aux 0
exec-timeout 5 0
transport preferred none
transport output none
line vty 0 4
exec-timeout 5 0
privilege level 15
transport input ssh
scheduler max-task-time 5000
ntp source Vlan1
ntp access-group peer 42
ntp server 192.168.0.1
end
Alain, you are my last hope, please help.
Alen
Hi Alen,
If I've got time this week-end I'll lab your topology in Dynamips to try to troubleshoot your problem because
just looking at your config I don't see obvious reasons why it is failing but maybe I should print it and take a better look at it.
If I have an idea I'll let you know don't worry.
Regards.
Alain.
Alain, thank you very much for your time!
I'll wait.
Best regards,
Alen
P.S. I am paying your attention on the fact, that not only marking is not working, but also shaping. Copying files from one side to another and jPerf one-side tests show up to 12mbps, full duplex - 6-7mbps!?
Can you post a diagram with the interfaces jotted down as well as the subnets.
You have no match for myDSCP on f0/0 input so it's normal traffic is not marked.
Are you sure traffic is coming in this interface :just put an ACL like this to verify
ip access-list COUNT
permit ip any any
int f0/0
ip access-group COUNT in
then let your traffic flow and do a show access-list
Regards.
Alain.
Yes! I found it!
After your question I understood I should not apply the marking policy to the physical interface, but to vlan subinterface. (Physical FA0 is L2 interface on the switch)
I changed it and now I can see traffic is being marked!!! And the parent policy on the tunnel interface is also showing something. It was obvious but I missed it (I missed it, because initially I thought I should apply any (including the marking) policy to logical interface inside an additional parent shape policy too, and failed while applying shaping on vlan1 for input traffic. (Now I even know, that shaping can not be applied onto incoming traffic ). After that I started to apply the policy onto physical interface).
So it finally started to work, but I still can see shaping is not working as it should. The branch router is transfering traffic at its full speed. Besides I mentioned some strange things with the QoS, but I'll be able to report tomorrow after an intensive tests.
Thank you for your help Alain!
I hope you will try to help with the shaping issue and any further questions with QoS functioning.
Well, I made some testing and here is the result (I emulate voice traffic using jPerf, plus simultaneously copy file. Both were in direction from the branch to Head office):
Branch#show policy-map int tunnel2
Tunnel2
      680338 packets, 1004663810 bytes
      5 minute offered rate 7709000 bps, drop rate 0 bps
      Match: any
      Queueing
      (pkts output/bytes output) 1629/313662
          455834 packets, 693779348 bytes
          5 minute offered rate 5712000 bps, drop rate 0 bps
          0 packets, 0 bytes
          Queueing
          222837 packets, 310709709 bytes
          5 minute offered rate 1961000 bps, drop rate 0 bps
          Queueing
          1667 packets, 174753 bytes
          Match: any
          Queueing
So:
1. QoS is likely working, but the strange thing is we got total 7709000 bps, 5712000 bps for VoIPT and 1961000 bps for LowPT, which means 2.91:1 ratio, not 3.8:1 as it should be (the show command was done after 7 minutes of not ended testing, so 5 minutes statistics is correct).
Why I have this ratio, not the right one?
2. Shaping is not working! It shows "target shape rate 1900000", but the same time "5 minute offered rate 7709000 bps, drop rate 0 bps". Why? And what to change to make shaping to work?
3. Should I set bandwidth to the class-default? I read in some documents, that only 75% of available bandwidth is distributed between user-defined classes and the remaining 25% is used for L2 overhead and other things plus class-default, but in newer documents I see this:
Class-Default and Bandwidth
The bandwidth assigned to the class-default class is the unused interface bandwidth not consumed by user-defined classes. By default, the class-default class receives a minimum of 1% of the interface bandwidth.
I can't understand, how much will get default class in case of congestion with user-defined classes? 1% or 25%?
3'. Let's take 2 situations:
- I have user-defined classes configured with "bandwidth percent" commands and in total with more than 75% of bandwidth. Class-default is not manually assigned bandwidth. How much of the totally available bandwidth will get user-defined classes and class-default in case of congestion? I expect (in fact just want) that each class would receive exactly assigned bandwidth and class-default - the rest (but not less than 1%).
- The same conditions but in total user-defined classes are configured with less than 75% of bandwidth. I expect that class-default would receive 25%, and all "congested" classes including class-default would receive additional bandwdith according to their weights.
Please tell me what we have in reality?
Thank you very much!
