Routing Problem with Cisco 887
Joachim.Geiger
Hello @ all,
i have a problem with the configuration of a 887. I tried all what i could find, but without any positive result.
The situation is the following:
and this is the running-config of the Cisco 887:
version 15.1
no service pad
hostname Cisco
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$dVpM$wuXK8tLkNpBiGnKCvOBwj/
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3512942905
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3512942905
revocation-check none
crypto pki certificate chain TP-self-signed-3512942905
certificate self-signed 01
........ (deleted)
quit
no ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1448C1AZ
controller VDSL 0
operating mode vdsl2
interface Ethernet0
ip address 172.16.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
description Net2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.0.3 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list acl1 interface Vlan1 overload
ip route 0.0.0.0 0.0.0.0 172.16.1.1
logging esm config
access-list 1 permit any
control-plane
line con 0
password admin
login
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
password admin
login
transport input all
end
Pingtests:
Testclient 1 -> 172.16.1.1                OK
Testclient 1 -> 192.168.0.1              OK
Testclient 1 -> 172.16.1.2                OK
Testclient 1 -> 192.168.0.3              OK
Testclient 1 -> 192.168.0.4              - Failure Overtime -
Testclient 2 -> Testclient 1               OK
Testclient 2 -> 172.16.1.1                OK
Testclient 2 -> 192.168.0.1               - Failure Overtime -
Router A -> 192.168.0.3                  OK
Router A -> 192.168.0.4                   - Failure Overtime -
So I am at the end of my knowing! :-)
I hope anybody can helb me!
8 Replies 8
Hi Joachim,
I see a few problem in the configuration of 887.
1. "ip nat inside source list acl1 interface Vlan1 overload"
We are natting the source IP to VLAN1 and VLAN1 is designated as NAT inside. This is incorrect as we NAT to the  "outside" interface.
2. source list used is "acl1" where else it should "1", as that is what you have created.
Change the nat statement to
"ip nat inside source list 1 interface  ethernet 0 overload"
Post if you still face any issue and rate the helpfulness please.
Sebastian
Do I really need a NAT?
I think it´s possible to do this with only a route or is that wrong? Whenn I take Wireshark, the packets who came on at Eth0 have the Source-IP for example from the Testclient 0.
Well NAT is necessary as you are using overlapping subnet on either side seperated by another L3 network boundary. To explain lets say Testclient2 wants to talk to testclient0 both are configured in common subnet of 192.168.0.x/24. Testclient2 initates an ARP for testclient1(as they are in same network) but ARP will fail as router cannot forward broadcast outside the layer 3 boundary in which it was initiated. Hence no arp , no ping.
We need to be able to change the source address of the traffic ariving in VLAN1 when going out.
Sebastian.
Oh sorry I think i have forgotten something!
Testclient 1 is only for some tests or for Wireshark an Management
In reality I only want to connect the Testclient 2 to the Testclient 0!
Joachim,
Well yes Testclient 2 and 0 are per diagram are in 192.168.0.0/24 subnet, however the two are seperated by another subnet. Hence they will not be able to discover eachother over layer2. So NAT becomes necessary in lieu to my explanation in earlier post.
Sebastian
1. I changed the nat statement to
     But now I´m not able to manage the router over the Eth 0 interface.
2. I have a question. Is it possible to give the Eth0 interface two vlans? So I can say, no 1 is for management and no 2 is for the traffic from testclient 0 to testclient 2.
Well eth cannot be a part of two vlans, since this was an L3 interface, however we can have two IP addresses on it using secondary command.
int eth0
ip add x.x.x.x  255.255.255.0
ip add y.y.y.y  255.255.255.0 secondary
Sebastian
ok. I thought so. bad ....
but when i configure eth0 with 192.168.0.3 /24 secondary and 172.16.1.2/24, then i can delete the ip address of the vlan interface. Now it should be possible to communicate between Testclient 0 and Testclient 2 right??   edit: this doesn´t work!
Thanks a lot for your help!
So I tried to configure a route again, so the testclient 2 can ping the testclient 0. Everything is good, but if i want to ping from testclient 0 to testclient 2, it doesn´t work. When i start wireshark on the testclient 2, the ping request are here but the testclient 2 doesn´t send it back. ???
Config static IP: 192.168.0.4 / 24 GW: 192.168.0.3
The following run-config is active:
Building configuration...
(deleted)
no ip source-route
ip cef
no ipv6 cef
controller VDSL 0
sync mode itu
interface Ethernet0
interface ATM0
no ip address
shutdown
description Net
interface Virtual-PPP1
no ip address
interface Vlan1
interface Dialer0
no ip address
no ip http server
logging esm config
(deleted)
end
