QoS on Sup2T
rinaldok1
Hi everyone,
I'm having some difficulty understanding QoS on Sup2T.  In much of the documentation, it is stated that Sup2T support MCQ style QoS configurations (using class-map and policy-map) vs older mls configs.
On a chassis with the following cards:
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 1000mb SFP WS-X6848-SFP
3 20 DCEF2T 4 port 40GE / 16 port 10GE WS-X6904-40G
4 20 DCEF2T 4 port 40GE / 16 port 10GE WS-X6904-40G
5 5 Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
6 20 DCEF2T 4 port 40GE / 16 port 10GE WS-X6904-40G
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6K-DFC4-A 1.2 Ok
3 Distributed Forwarding Card WS-F6K-DFC4-E 1.2 Ok
4 Distributed Forwarding Card WS-F6K-DFC4-E 1.2 Ok
5 Policy Feature Card 4 VS-F6K-PFC4 1.2 Ok
5 CPU Daughterboard VS-F6K-MSFC5 1.4 Ok
6 Distributed Forwarding Card WS-F6K-DFC4-E 1.2 Ok
From this document (https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/white_paper_c11-652042.html#_Toc474220195), it states:
"Due to differences in queueing implementation in port ASICs, Modular Quality of Service (MQC)-compliance in PFC3-based Cisco Catalyst 6500/6800 systems is limited to marking and policing. Queuing configuration can map incoming traffic to a specific queue, allowing other functionalities such as trust, global maps, and more. This is configurable through platform-specific command-line interfaces (CLI). PFC4-based Supervisor 2T system removes these limitations by supporting C3PL, which is a policy-driven CLI syntax, for marking, policing, and queueing."
As this is a PFC4, my assumption was that the simple configuration below should work as it does on other platforms (3650/3850, 4500, etc.):
class-map type lan-queuing match-any Internetwork-Ctrl
 match dscp cs6
class-map type lan-queuing match-any Control-Traffic-Queue
 match dscp cs6
 match dscp cs3
class-map type lan-queuing match-any Priority-Traffic-Queue
 match dscp ef
 match dscp cs4
class-map type lan-queuing match-any Multimedia-Conf-Queue
 match dscp af41
policy-map type lan-queuing QoS-Output-Policy
 class Priority-Traffic-Queue
  priority
 class Control-Traffic-Queue
  bandwidth remaining percent 10
 class Multimedia-Conf-Queue
 class class-default
  bandwidth remaining percent 25
However, when I apply the service-policy to an interface, it gives me an error:
"priority command is not supported in output direction for this interface"
I have tried this with and without the "type lan-queuing" configuration, and with and without "platform qos queuing-only" configured.
If I try to use AutoQoS, it results in myriad configurations applied to interface that resemble older mls configurations, such as the following:
interface GigabitEthernet1/1
 description -
 ip address -
 ip flow monitor m1 input
 ip ospf network point-to-point
 wrr-queue bandwidth 20 100 200
 priority-queue queue-limit 5
 wrr-queue queue-limit 65 15 15
 wrr-queue random-detect min-threshold 1 70 100 100 100 100 100 100 100
 wrr-queue random-detect min-threshold 2 70 100 100 100 100 100 100 100
 wrr-queue random-detect min-threshold 3 40 40 50 50 60 60 70 70
 wrr-queue random-detect max-threshold 1 100 100 100 100 100 100 100 100
 wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
 wrr-queue random-detect max-threshold 3 70 70 80 80 90 90 100 100
 wrr-queue cos-map 2 1 1 2
 wrr-queue cos-map 3 5 3 4
 wrr-queue cos-map 3 7 6 7
 auto qos voip trust
end
What I'm trying to achieve is simply have the 6500 prioritize VoIP traffic as described in the simple policy-map/class-map.  Is there a simpler way to achieve this on the Sup2T?  I would really prefer to use the "service-policy input/output" syntax vs. the example above, as I have a very hard time deciphering what is happening.
Thanks for any assistance.
patoberli
Check here: https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/white_paper_c11-652042.html
Section 3.4.2 states:
The line card is capable of port level shaping; however, this will be supported in a post-FCS software release.
Which software are you running at the moment?
15.0(1)SY2
I get the same results on the WS-X6848 line cards as well as the WS-X6904 cards.
To me it seems like the current state is halfway between mls qos and MQC.  I'm surprised I'm not finding more info on this platform/issue.
It might be a software restriction, but I don't know exactly, just guessing.
Check here the release notes for 15.1:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/release_notes.html
Interesting points:
- Hierarchical shaping and two priority queues on WS-X6904-40G-2T
- Global QoS Policy
- Egress Microflow Destination-Only Policing
