QOS on SVI
JOHN APONTE
I have the following:
WS-SUP720-BASE
L3 Switching Engine III WS-F6K-PFC3A
CATOS/IOS hybrid code
Trying to apply a service-policy output QOS_POLICY on a SVI that connects across to another 6500 with a WS-X6K-SUP2-2GE/WS-F6K-PFC2 also running CATOS/IOS hybrid code. I am trying to apply the policy on a L3 interface vlan that connects both boxes across a gige pipe. I am able to apply the QOS policy on the SUP2 box with a L3 SVI interface but on the SUP3 with a L3 SVI interface when I try to apply the policy I am getting the folowing error 'MQC features are not supported for this interface'. Why does the policy stick on the SUP2 module but not on the SUP3 module.? Thanks for your support.
16 Replies 16
Lucien Avramov
Level 10
Level 10
Some linecards do not support QOS on SVI. It's not really a sup problem but it depends on the supported features the linecards on the chassis have.
Here is a snapshot of the different line cards:
WS-X6K-SUP2-2GE
WS-F6K-MSFC2
WS-X6348-RJ-45
WS-X6324-100FX-MM
WS-X6416-GBIC
WS-X6416-GBIC
WS-X6348-RJ-45
WS-X6416-GBIC
2nd chassis:
WS-X6748-GE-TX
WS-X6748-GE-TX
WS-X6748-GE-TX
WS-X6748-GE-TX
WS-SUP720-BASE
WS-SUP720
WS-X6524-100FX-MM
WS-X6724-SFP
WS-X6724-SFP
WS-X6724-SFP
Are you applying it inbound or outbound...? I think the direction is important.
Edit.. reread and noticed your applying outbound.
Could you post the sub module section of a show mod on both 65's
6509/w sup 2
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
1 L3 Switching Engine II WS-F6K-PFC2 SAL082809Z3 3.4
3 Inline Power Module WS-F6K-VPWR 1.0 1.0
6509 switch w/ sup 720
1 Centralized Fwd Card WS-F6700-CFC SAD092508EZ 2.0
2 Centralized Fwd Card WS-F6700-CFC SAL083325EN 2.0
3 Centralized Fwd Card WS-F6700-CFC SAL08321MMW 2.0
4 Centralized Fwd Card WS-F6700-CFC SAL08465Y3D 2.0
5 L3 Switching Engine III WS-F6K-PFC3A SAD083108BG 2.4
7 Centralized Fwd Card WS-F6700-CFC SAL08321MHT 2.0
8 Centralized Fwd Card WS-F6700-CFC SAL08321MQX 2.0
9 Centralized Fwd Card WS-F6700-CFC SAL082800U7 2.0
Looks like you have no MSFC card this is what performs the software queues for layer 3 interfaces.
Your running PFC qos which is slightly different to full mqc, its hardware based.
The "output service-policy" command is unavailable.
There is 1 msfc in each of the 6509's:
15 5 1 Multilayer Switch Feature WS-SUP720 no ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
could you post "show mod 7" on the 720 6500
ds104a> (enable) sh mod 7
Mod Slot Ports Module-Type Model Sub Status
7 7 24 1000BaseX Ethernet WS-X6724-SFP yes ok
Mod Module-Name Serial-Num
7 SAL08373TRP
Mod MAC-Address(es) Hw Fw Sw
7 00-11-93-38-9b-90 to 00-11-93-38-9b-a7 2.1 8.5(8) 8.5(8)
ds104a> (enable)
Sorry i thought that was the module port your supervisor was installed on...
Could you do the same command for the supervisor port.
The 15 1 1 you provided earlier indicates module 15 (ie there is no mod 15) which I think means you have a problem with your MSFC card.
ds104a> (enable) sh mod 5
5 5 2 1000BaseX Supervisor WS-SUP720-BASE yes ok
5 SAD083207ZU
5 00-11-21-b9-93-20 to 00-11-21-b9-93-23 3.1 8.1(3) 8.5(8)
00-11-5d-cd-bc-00 to 00-11-5d-cd-bf-ff
ds104a> (enable)
my show mod for the sup looks like this...
CC-LC-SW1#show mod 7
Mod Ports Card Type Model Serial No.
7 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1232ZQJB
Mod MAC addresses Hw Fw Sw Status
7 0016.9de6.adf4 to 0016.9de6.adf7 5.7 8.5(2) 12.2(33)SXH4 Ok
Mod Sub-Module Model Serial Hw Status
7 Policy Feature Card 3 WS-F6K-PFC3B SAL1232ZVHA 2.4 Ok
7 MSFC3 Daughterboard WS-SUP720 SAL1232ZTUZ 3.2 Ok
Mod Online Diag Status
7 Pass
yours doesnt state an MSFC
could you post the full show mod.
Could be barking up the wrong tree, though i would have thought the MSFC card would show as a daughterboard card under the sub-module section.
Have a look at this document.
https://www.cisco.com/en/US/products/hw/switches/ps708/products_qanda_item09186a00809a7673.shtml#qa5
Basically states that the DFC is used to provide the local QOS features and the CFC doesnt.
It agrees with lavramov initial diagnosis
Correct, CFC doesnt, I was suspecting this.
Thanks for proving it with the show modules.
I guess we can mark this post resolved.
