QoS question
marcelnjkoks
Hi, i have been reading up on QoS on Cat3750's, and there is something i do not understand from this section:
http://www.cisco.com/en/US/customer/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml#def-config
Where does the 4% absolute come from on queue1?  Does it have something to do with the fact that by default all egress queues have 25% of the bandwidth available, but queue 1 has a 25% shaped weight (others have 0)?
And what effect has the priority-queue output command on this?
Thanks!
Lei Tian
Once qos is enabled, queue 1 will be shaped to 4% by the default srr-queue bandwidth shape 25 0 0 0config on all interfaces. This 25 is not a percentage, it is 1/25. If priority-queue out is configured on the interface, all the shape or share weight applied to queue 1 will be ignored. Traffic in queue 1 will receive strict priority, and be served first over all other queues.
HTH,
Lei Tian
Lei Tian
HTH,
Lei Tian
Hi Lei Tian,
Thanx, this completely clears it up for me. The documentation is not to clear about this.
Very helpful!
You are welcome! Thanks for the great rating!
Cheers,
Lei Tian
