Qos question.
saintjmf
3 threshold 3  0
mls qos srr-queue output cos-map queue 4 threshold 3  1
mls qos srr-queue output dscp-map queue 1 threshold 3  46
What is the threshold ID used for?
Troy Jackson
It allows you to adjust the queue thresholds so that packets with lower priorities are dropped. The ID just designates what thresholds are configurable and where they are assigned. Threshold 3 is not configurable and is set to the full queue size. You can find the info here in this link.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swqos.html#74446
Please remember to rate useful posts, by clicking on the star below.
-Troy J.
