VRF Nat issue
Ramana1984
Community Member
I have 3 routers.
R1 (Loop back 206.87.176.20)
R2 (Source NAT : 206.87.176.20 ---> 10.14.1.1)
R3(loop back 172.28.20.20).
Between R1, R2 -we are running vrf.
I am able to ping from R1 to R3 loopback , which is Natted on R2.(Source NAT).
From R3 , not able to reach R1.
Working:
R1:
ping vrf NSCU 172.28.20.20 source Loopback20
Sending 5, 100-byte ICMP Echos to 172.28.20.20, timeout is 2 seconds:
Packet sent with a source address of 206.87.176.20
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/32/44 ms
Config on R2:
ip nat outside source static 206.87.176.20 10.14.1.1 vrf NSCU extendable
Debug on R3:
 ICMP: echo reply sent, src 172.28.20.20, dst 10.14.1.1, topology BASE, dscp 0 topoid 0
Not working:
R3:
ping 10.14.1.1
Sending 5, 100-byte ICMP Echos to 10.14.1.1, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
Debug on R2:
NAT*: Can't create new inside entry - forced_punt_flags: 0
R1 : Debug
ICMP: dst (10.14.1.1) host unreachable sent to 192.168.200.14
Please suggest
Hello
Can you post a simple topology diagram for this and if applicable the configuration on all three rtrs
res
Paul
Kind Regards
Paul
amikat
Can you please try to add the parameter "add-route" to your R2 ip nat command, ie:
"ip nat outside source static 206.87.176.20 10.14.1.1 vrf NSCU add-route extendable"
and see if there is any improvement.
Best regards,
Antonin
