05-01-2013 07:00 AM - edited 03-07-2019 01:07 PM
Background: We currently have a site with a very simple topology that uses a 3750X switch stack for a collapsed core. Everyday, the users have a conference call and experience poor voice quality. Its not bad when users call from several conference phones, but when everyone calls in on individual phones, there is choppy and almost inaudible voice quality experienced. The voice traffic flow would be as follows: Phone <-> 3750 switch <-> Voice GW
We have packet captures showing that RTP packet loss is occuring from the phone to the voice gateway, but none from the voice gateway to the phones. We also have drops in the output queues that match drops on the asics. I can reset the counters and they will be clear until the call, and then they increment significantly during the call. The voice gateway and phones are non-Cisco. The switch stack has 6 switches. We are trusting the DSCP settings on the phones. All the queue drops from the phones are usually in queues 0-3, but all drops on the voice gateway is in queue 0. Below are the QoS settings; they are mostly default and we have not changed any queuing, thresholds, or buffers. Should we specify larger buffers and threshold for a designated queue and send EF traffic to that queue?
MySwitch#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is disabled
Typical Port
GigabitEthernet1/0/4
trust state: trust dscp
trust mode: trust dscp
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
MySwitch#sh mls qos queue-set
Queueset: 1
Queue : 1 2 3 4
buffers : 25 25 25 25
threshold1: 100 200 100 100
threshold2: 100 200 100 100
reserved : 50 50 50 50
maximum : 400 400 400 400
Queueset: 2
Queue : 1 2 3 4
Interface directly connected to voice gateway
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 30174799 0 0
queue 1: 163475 814 83213
queue 2: 42826 0 0
queue 3: 4265 0 2677
output queues dropped:
queue 0: 126997 0 0
queue 1: 0 0 0
queue 2: 0 0 0
queue 3: 0 0 0
05-01-2013 09:59 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Have you enabled PQ on the interfaces? If not, try that first.
If you have, or that alone doesn't fix your issue, then some tuning should be tried. If the drops are only seen on the egress port to the GW, assuming you're not using queueset 2, we can set that port to use that queueset and tune it independently of your other ports. For example, we might next try Q1, WTD1 at 200.
