VSS multi-chassis etherchannel question
Colin Higgins
Level 2
Level 2
I assume I can do this, but I want to check before I try and implement
I have 2 6500 series switches is a VSS environment. They are virtualized using the TenGig ports on the Sup 2Ts.
I want to trunk both switches (or the one virtual switch) to a pair of upstream 6513s that are not virtualized (just a standard setup).
The examples I have seen use a layer 3 MEC between the virtualized switches and the upstream switches, but I need to trunk vlans and do not want to use layer 3.
So on the upstream switches, I would like to set up something like this
interface port-channel 10
switchport mode trunk
mls qos trust dscp
no shut
interface range TenGigabitEthernet 12/1 -2
channel-group 10 mode desirable  no shut
and do po20 on the other switch ...
so po10 has a connection to each virtual switch, and so does po20
Any issues with this?
Reza Sharifi
Yes, you can do this, but if you are not planning to use Layer-3, and the portchannel is just layer-2 trunk, then you can put all you 4 links in one portchannel.  There is no need to the second portchannel unless you are doing MEC (layer-3).
Reza Sharifi
