07-27-2015 02:07 AM - edited 03-08-2019 01:07 AM
07-27-2015 03:52 AM
is the marking taking place at the source? are you using Cisco phones?
If you just want to trust the markings that are already been set and allow them to be carried you can just set the up links to mls qos trust dscp , if using cisco phones you can set the edge ports to mls qos trust device cisco phone or non cisco you can use the mls qos trust dscp again or if dscp is not supported at access layer use cos but make sure your cos-dscp mapping is in place on local switch mls qos map cos-dscp 0 8 16 24 32 46 48 56
07-27-2015 07:42 AM
Thank you for your reply
there is not a cisco-phone
where is what configured in the 2960 and 4500 ! is it correct !
sur le switch C2960X -POE :
mls qos map policed-dscp 0 10 18 24 46 to 8
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
epm logging
interface GigabitEthernet1/0/4
switchport access vlan Data
switchport mode access
switchport voice vlan Voice
srr-queue bandwidth share 1 30 35 5
queue-set 1
priority-queue out
mls qos trust dscp
auto qos voip trust
spanning-tree portfast
-----------------------------------------Catalyst 4500------------------------------------
policy-map VVLAN-POLICERS
class VVLAN-VOICE
set dscp ef
police 128k bc 8000
conform-action transmit
exceed-action drop
class VVLAN-SIGNALING
set dscp cs3
police 32k bc 8000
exceed-action drop
class class-default
set dscp default
police 32k bc 8000
exceed-action drop
policy-map DVLAN-POLICERS
class MULTIMEDIA-CONFERENCING
set dscp af41
police 5m bc 8000
exceed-action drop
class SIGNALING
set dscp cs3
police 32k bc 8000
exceed-action drop
class TRANSACTIONAL-DATA
set dscp af21
police 10m bc 8000
exceed-action set-dscp-transmit cs1
class BULK-DATA
set dscp af11
police 10m bc 8000
class SCAVENGER
set dscp cs1
police 10m bc 8000
exceed-action drop
class class-default
set dscp default
police 10m bc 8000
VLAN DATA
service-policy input DVLAN-POLICERS
VLAN VOIP
service-policy input VVLAN-POLICERS
07-28-2015 12:57 AM
2960 looks fine , the 4500 looks to be running the Borderless Campus design setup just make sure when you have the voice set to 128kpbs it only supports codecs g7.11, g7.22,g7.29 so if you using a different codec you may require more bandwidth
Are you having issues currently with this setup with voice calls ?
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/Borderless_Campus_Network_1-0/Borderless_Campus_1-0_Design_Guide/BN_Campus_QoS.html
07-28-2015 10:14 AM
Thank you very much for your help.
I'll do the first tests next week
08-21-2015 10:31 AM
I connected the switch poe on our Catalyst 4500, the telephone SIP works well
I applied the qos on our 4500 router and switch 2960 poe on the data VLAN and voip,
Users have a slow networks when the service-policy input DVLAN-POLICERS is enabled on the VLAN data then back to normal when I disable this option.
i don't understand
I have no telephon SIP is connected to the routeur 4500
it is necessary to apply service-policy input DVLAN-POLICERS in vlan data ?
thanks in advance
12-05-2015 01:26 PM
07-27-2015 06:08 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You'll need to provide additional information.
What are you specifically worried about in your existing configurations? What specific devices are in play, including their specific IOS? What's you're overall QoS model?
