QSFP Splitter Cable on Nexus 3172
sslittle
I am interested in using the QSFP Passive Copper Splitter Cables that breaks a 40Gig port into 4 x10Gig copper SFP+ and below is the exact part number. Can I connect the 4x10Gig cable ends to different Cisco Switches or do all four 10Gig ports need to connect to the same device at the 10Gig end?
QSFP-4SFP10G-CU3M Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 3-meter, passive
If possible I would like to connect each of the 10Gig connections to a different Cisco 2960X switch using the splitter cable to the 3172 40gig port at the 3172 end?
Thx
Reza Sharifi
Connecting the 10Gig sides to different devices should not be an issue.  I have connected the 4 10Gigs to 4 different FEXes.
