Quad VSS failover
JAMES WEST
Level 5
Level 5
We have a pair of 6500 with 2 x VS-S720-10G supervisors in each chassis running VSS & SSO mode -
Switch 1-
5   5 Supervisor Engine 720 10GE (Active)   VS-S720-10G
6   5 Supervisor Engine 720 10GE (RPR-Warm) VS-S720-10G
Switch 2 –
5   5 Supervisor Engine 720 10GE (RPR-Warm) VS-S720-10G
6   5 Supervisor Engine 720 10GE (Hot)       VS-S720-10G
The above scenario Switch Sup module 5 failed on Switch 1, Switch 2 module 6 then took over the active role, but all the VSL links where lost between the chassis and switch 1 reset all of the line cards. This caused the single homed servers etc to lose connectivity for around 7 minutes.
Channel Mode1        Channel mode 2
Sw1Te1/5/4      <->      Te1/5/4 Sw2
Sw1 Te1/6/4     <->      Te1/6/4 Sw2
Jul 15 12:54:07.429: %CONST_DIAG-SW2_SPSTBY-4-HM_TEST_WARNING: Sup switchover will occur after 10 consecutive failures
Jul 15 12:54:31.051: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/13, changed state to down
Jul 15 12:54:31.075: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/13, changed state to down
Jul 15 12:54:29.334: %VSLP-SW1_SP-3-VSLP_LMP_FAIL_REASON: Te1/5/4: Link down
Jul 15 12:54:29.334: %VSL-SW1_SP-5-VSL_CNTRL_LINK:  New VSL Control Link Te1/6/4
Jul 15 12:54:29.614: %VSLP-SW1_SP-3-VSLP_LMP_FAIL_REASON: Te1/6/4: Link down
Jul 15 12:54:29.614: %VSLP-SW1_SP-2-VSL_DOWN:   Last VSL interface Te1/6/4 went down
Jul 15 12:54:29.642: %VSLP-SW1_SP-2-VSL_DOWN:   All VSL links went down while switch is in ACTIVE role
Jul 15 12:54:29.758: %PFREDUN-SW1_SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
Jul 15 12:54:30.203: SW1_SP:  Switch 2 Physical Slot 5 - Module Type LINE_CARD  removed
Jul 15 12:54:31.599: SW1_SP:  Switch 2 Physical Slot 1 - Module Type LINE_CARD  removed
Jul 15 12:54:33.675: SW1_SP:  Switch 2 Physical Slot 2 - Module Type LINE_CARD  removed
Jul 15 12:54:34.799: SW1_SP:  Switch 2 Physical Slot 3 - Module Type LINE_CARD  removed
Jul 15 12:54:35.595: SW1_SP:  Switch 2 Physical Slot 4 - Module Type LINE_CARD  removed
Jul 15 12:54:36.347: SW1_SP:  Switch 2 Physical Slot 6 - Module Type LINE_CARD  removed
Jul 15 12:54:37.386: SW1_SP:  Switch 2 Physical Slot 7 - Module Type LINE_CARD  removed
Jul 15 12:54:38.122: SW1_SP:  Switch 2 Physical Slot 8 - Module Type LINE_CARD  removed
Can some one let me know if the VSL link on Sw1 Mod 5 fails, should this take down the whole switch? Or should we just lose the Module and then the Supervisors determine their Active/Hot/Stand-by roles?
James
7 Replies 7
Reza Sharifi
James,
Currently even with quad Sup per VSS pair when the primary Sup fails the switch will reboot.  In the future IOS releases, when for example module 5 fails, the switch will fail over to module 6 without rebooting, but that is not the case today.
Reza
Reza,
Thanks for the reply +5
I have been reading and re-reading the PDF's and just wanted to make sure that was the case.
Hope you have a good weekend.
James
Eduardo Aliaga
Level 9
Level 9
So what's the advantage of Quad VSS versus original VSS ?
Basically the only advantage is that with single sups if the active sup failed and the switch rebooted then it wouldn't come up because the sup has failed.
With 2 sups in the chassis if the active sup failed and the switch reboots then it can come up with the other sup.
Jon
IS it working on SSO ?
No, not yet.  It is RPR right now, but in the feature it will be SSO.
Out of interest do you or does anyone else know when Quad Sup SSO is expected to be introduced into the IOS codebase? It seems to be a long time comming and now that Cisco is tied up with the new Sup2T and features they might want to implement on that I think it might be even longer before we see such a feature?
Kev
