3750 stacking problems
paulkilcoyne
Level 2
Level 2
Hi there,
I've just installed a 3750 two switch poe stack between a 3750v2-48PS ( slave ) and a WS-C3750E-48PD ( master ).
I'm running the following IOS on both respectively:
c3750-ipservicesk9-mz.122-58.SE2.bin
c3750e-universalk9-mz.150-1.SE.bin
Are these compatible?
The stack seemed to be working fine but today a number of times the WS-C3750E-48PD locked up, all ports went down and so too did PoE. The 3750v2-48PS then took over as master.
Any ideas as to what this problem might be?
Attached is the log from the stack.
Many thanks,
Paul
2 Accepted Solutions
Edison Ortiz
Reza Sharifi
Paul,
For a stack to work correctly, you need to have the same exact IOS installed in both switches, if not you will have problems.
Edison Ortiz
Reza Sharifi
Paul,
Guys,
thanks so much for your speedy response. I'll go make them run the same IOS and let you know.
Paul
Glad to help Paul,
Good luck and thanks for the rating
Reza
