quesiotn about switch with 2.5G port
ronald.su
hello there,
recently, we want to deploy Ruckus AP with cisco Catalyst switch.
Our Ruckus AP is R650 and it support 1G and 2.5G link, so we want to choose a switch which suport 2.5G
we found a model:
C9200L-48PXG-4X-E  and SPEC:
Catalyst 9200L 48-port 12xmGig, 36x1G, 4x10G PoE+, Network Essentials
can this support Ruckus R650 AP with 2.5G ?
thanks
pieterh
look at this document Transform the Workspace with Cisco Multigigabit Ethernet White Paper - Cisco
 Cisco Multigigabit Ethernet switches and access points use 802.3bz standard
-> if Ruckus also uses this standard, you should be good to go
on the Ruckus website I only find a match for 802.3bz and the R720 AP
RUCKUS® R720 (ruckuswireless.com)
the R650 does not mention 802.3bz
R650: Indoor Wi-Fi 6 (802.11ax) 4x4:4 Wi-Fi Access Point with 2.5Gbps backhaul and 6 spatial streams (ruckuswireless.com)
