question about using Distribute list and ACL in bgp filtering
Dr.X
Level 2
Level 2
hi ,
i want to ask about some thing ;
in order to match prefix /prefix lenght using ACL , we put the word host
example :
access-list 100 permit ip host 10.0.0.0 host 255.0.0.0
this will match 10.0.0.0/24  prefix/prefix lenght
my questuion is , if i type ,
access-list 100 permit ip host 10.0.0.0  255.0.0.0  0.0.0.0 0.0.0.0
will this will match the route 10.0.0.0/24 prefix/prefix lenght ??
or it will match any route that start with 10.0.0.0 to 10.255.255.255 ???
i mean is there another shape of ACl that can match prefix/prefix lenght of a route another than using "host"
word.
another question,
doees this rule applicable to another IGP routing protocols like ospf ACL ditribute list , or it  is only a special rule for BGP filtering issu??
regards
2 Accepted Solutions
Hello Ahmed,
no, the third statement does not provide same results
> access-list 100 permit ip  10.0.0.0  255.0.0.0  0.0.0.0 0.0.0.0
This will match an IPv4 prefix with arbitrary first byte, all other bytes set to 0 with a subnet mask of 0.0.0.0. In practice only a default route 0.0.0.0/0 can match this statement
In IP access-list the order of parameters is very important and makes huge difference!
the schema is
access-list N  permit|deny   ip  network_base_Address network_base_address_wildcard_mask Subnet_mask Subnet_Mask_wildcard
with the subnet mask taking the position of the destination address
Hope to help
Giuseppe
no it won't , it will match all IP addresses. EDIT: with a deny it filtered all ip addresses in the test i did on GNS3)
Regards.
Alain
7 Replies 7
cadet alain
example :
No, this will match 10.0.0.0/8  for /24 you should have host 255.255.255.0
2)
No it will do the same as above command as  host is a shortcut for 0.0.0.0
3) to my best knowledge as a replacement to prefix-list it can only be used in BGP
Regards.
Alain
hi  , again :
is the command
is the same as
will match only one route which is 10.0.0.0/8 ????????
Giuseppe Larosa
Hello Ahmed,
the modern way to do this kind of  prefix filtering is the use of IP prefix-lists that have been introduced for this job.
About the syntax to be used for IP extended ACL
matches only 10/8 and does not match more specific subnets
This is equivalent to
access-list 100 permit ip 10.0.0.0 0.0.0.0 255.0.0.0 0.0.0.0
the following
is wrong  because there is one 0.0.0.0 that is not needed
That command would be rejected by CLI parser I guess
The following can be used:
As Alain has noted IP extended ACLs are not supported for IGP.
Hope to help
Giuseppe
hi, in the 1st post there was a typo , sorry for that ,
my question again
both of
will give the same result of matching the  prefix/prefix lengh of 10.0.0.0/8 route .
now ,  the question is
does
will give the same result of the 1st two lines that i typed ???
regards
Hello Ahmed,
the schema is
Hope to help
Giuseppe
Regards.
Alain
thank u both ,
does this rule "using host " word , applicable only to bgp distribulte list ??
or we can usr the same rule in match prefix/prefixlengh in eigrp & ospf ??
regards
