Question On 3750 Asics
tecra810076
Community Member
We have a stack of 3750 switches in a stack.
I am trying to understand the command show platform pm if-numbers
When do the command I get the follwing - I only grabbed two ports the rest are not shown
interface gid gpn lpn port slot unit slun port-type lpn-idb gpn-idb
Fa1/0/9 11 11 9 1/10 1 9 11 local Yes Yes
Fa2/0/9 65 65 9 1/10 2 9 11 remote No Yes
My question is if I understand what I read these ports are on asic 1 port 10.
Now I do the command
sh platform port-asic stats drop port 10 asic 1
I get the following output
Port-asic Port Drop Statistics - Summary
  RxQueue 0 Drop Stats: 0
  RxQueue 1 Drop Stats: 0
  RxQueue 2 Drop Stats: 0
  RxQueue 3 Drop Stats: 0
  Port  0 TxQueue Drop Stats: 0
  Port  1 TxQueue Drop Stats: 0
  Port  2 TxQueue Drop Stats: 0
  Port  3 TxQueue Drop Stats: 0
  Port  4 TxQueue Drop Stats: 6429
  Port  5 TxQueue Drop Stats: 326
  Port  6 TxQueue Drop Stats: 6395
  Port  7 TxQueue Drop Stats: 11
  Port  8 TxQueue Drop Stats: 28501
  Port  9 TxQueue Drop Stats: 7381
  Port 10 TxQueue Drop Stats: 1991
  Port 11 TxQueue Drop Stats: 575614
  Port 12 TxQueue Drop Stats: 1479
  Port 13 TxQueue Drop Stats: 32635
  Port 14 TxQueue Drop Stats: 0
  Port 15 TxQueue Drop Stats: 0
  Port 16 TxQueue Drop Stats: 1173
  Port 17 TxQueue Drop Stats: 1845
  Port 18 TxQueue Drop Stats: 11
  Port 19 TxQueue Drop Stats: 0
  Port 20 TxQueue Drop Stats: 23726
  Port 21 TxQueue Drop Stats: 13483
  Port 22 TxQueue Drop Stats: 16511
  Port 23 TxQueue Drop Stats: 2936
  Port 24 TxQueue Drop Stats: 5514
  Port 25 TxQueue Drop Stats: 2772
  Supervisor TxQueue Drop Statistics
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 0
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 0
    Queue  8: 0
    Queue  9: 0
    Queue 10: 0
    Queue 11: 0
    Queue 12: 0
    Queue 13: 0
    Queue 14: 0
    Queue 15: 0
Port-asic Port Drop Statistics - Details
  RxQueue Drop Statistics
    Queue 0
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 1
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 2
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 3
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
  Port 10 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 1
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 1990
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 0
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 0
    Queue  8: 0
    Queue  9: 0
    Queue 10: 0
    Queue 11: 0
    Queue 12: 0
    Queue 13: 0
    Queue 14: 0
    Queue 15: 0
My assumption is I am looking at the ASIC on switch 1. How do I look at the drops on switch 2?
singhaam007
Level 9
Level 9
Hello Dave ,
you can try
show platform port-asic stats drop fastEthernet 2/0/10
or sh platform port-asic stats drop port 10 hopefully it will give you infromation for both Switches.
thanks
Mark Walters
I believe that the output from "show platform pm if-numbers" aggregates output from each switch, but some other "show platform" commands must be run directly on the switch in question.  Note that each switch in the stack still has it's own ASICs/ports (and the numbers are identical/reused).  So in your output above your port Fa1/0/9 is on ASIC 1 of switch1, and your port Fa2/0/9 is on ASIC 1 of switch 2.
So if you want to see portspecific info for FA1/0/9, your command would work:
SWITCH# sh platform port-asic stats drop port 10 asic 1
Then to see the counters for Fa2/0/9, which is on switch 2, try this:
SWITCH# session 2
SWITCH-2# sh platform port-asic stats drop port 10 asic 1
Or this should work as well:
SWITCH# remote command 2 sh platform port-asic stats drop port 10 asic 1
I don't pretend to be a hardware guru, so take with a grain of salt!
cheers
mark
