VTPV3
MUKUL JOSHI
Level 2
Level 2
Hi All,
Want to know the differences between vtpv2 nd v3?
Whether vtpv3 can advertises mst instance in it's updates ?
Best Regards
MJ
venkata dandu
Level 2
Level 2
VTP V3 adds some security features into VTP like
  • Primary Server - You can have only one primary server in your domain and only the primary server can update the vtp domain.
  • Secondary Server - You can any number of secondary servers in your domain for backup, and any new/old switch accidentally connected to the network in server mode with higher revision number can only act as a secondary server, so it can't update the domain.
  • MST Instance database - VTP can advertise MST-Instance mapping to the domain.
Hope to help. Please rate if this is useful.
Hi Venkata,
I am just confused on MST part....My question is ...
If i enable vtpv3 and configure a new mst instance on primary server than that mst instance will automatically get advertised to other switches or not ?
Or i have to manually configure MST on all the switches.
Best Regards
MJ
