Question on router vulnerability fix
Jagan1976
John Blakley
There aren't patches that you install on the routers. The only thing that you could do would be to either update the IOS to one of the later versions, or you could disable the services that are affected by these vulnerabilities.
HTH,
John
HTH, John *** Please rate all useful posts ***
Ok understood. Just found out that you can block the ICMP timestamp via ACLs.
