Question on Subnets and Wild Card Masks
incognito_54
Hello's
I would like to request some help in summarizaing and wildcard masks.
I have the following subnets that i'd like to summarize and then use the summary address in an Access list. Is this possible?
Here are the ranges:
172.22.96.0/19
172.22.128.0/19
172.22.160.0/19
thanks
Inc.
Jerry Ye
How much summerization are you planning?
You can summerized them into a single /16
172.22.0.0 255.255.0.0 (reverse mask for ACL is 0.0.255.255)
or one /19 and one /18
172.22.96.0 255.224.0.0 (reverse mask for ACL is 0.31.255.255)
172.22.128.0 255.192.0.0 (reverse mask for ACL is 0.63.255.255)
jerry
8 Replies 8
Jerry Ye
jerry
Jerry is correct in that you can summarise them with 2 entries -
note though that there is a typo - reverse masks should be 0.0.31.255 and 0.0.63.255
Jon
I agree with Jon and use the following:
Sal
If I have worked this out correctly then you could do it with a wildcard of 0.0.224.255.
This will allow x.x.96.x, x.x.128.x and x.x.160.x
However, it also allows x.x.0.x, x.x.32.x, x.x.64.x, x.x.192.x and x.x.224.x , which you may not want.
Pete
PS - Any corrections welcome :-)
incognito_54
I'm a little confused from the responses. Perhaps its the typo mentioned.
One of the responses given was 172.22.96.0  255.224.0.0 ...... Was this meant to be 172.22.96.0  255.255.224.0 with a reverse of 0.0.31.255?
The second response given was 172.22.128.0  255.192.0.0 ....... Was this meant to be 172.22.128.0  255.255.192.0 with a reverse mask of 0.0.63.255?
thanks again for your time.
Inc.
Inc.
Yes it was meant to be -
172.22.96.0   255.255.224.0  - reverse mask 0.0.31.255
172.22.128.0 255.255.192.0  - reverse mask 0.0.63.255
Jerry just made a typo which is very unusual for him as he is normally spot on.
Jon
Guys,
Thanks so much for your speedy responses. Much much appreciated.
Inc.
Thank Jon for correcting my typo.
jerry
