Question re. Layer 2 Netflow command on 6509
shanemoss
Level 4
Level 4
Hi Folks,
I've inherited some 6509s and included in the config is the command;
ip flow ingress layer2-switched vlan 10,20
I'm not interested in capturing layer two netflow statistics, so was going to remove the command, my question is, is this command doing anything other than capturing layer two Netflow statistics? And therefore safe to remove without affecting performance?
Many thanks in advance,
S.
Rasika Nayanajith
Yes, u can safely remove this command and it does not have any impact other than l2 netflow monitoring capability.
Rasika
**** pls rate all useful responses ****
Rasika Nayanajith
Rasika
