Questions about 2960s and 4948e
martos1981
Hi guys,
I have a couple of questions that I could not find answer.
Do these switches both support q-in-q?
Can I use regular SFP in the SFP+ slot?
Calin C.
Level 5
Level 5
I could not find any IOS version to support q-in-q for 2960 or 4948, so I guess it's not supporting it.
Also to your second question, I didn't find anything again using sfp modules in sfp+ slots.
Hitesh Vinzoda
Level 4
Level 4
I had never seen q in q in the 2960 configuration guides section so i m pretty sure that it doesnt support q in q. I also remember that when one of my friend was designing metro ethernet for a company, Cisco advised him to use 3750 at the access layer, could be one of the reason.
and 4948E do support q in q tunneling.. below is the link from cisco where you can confirm it...
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps10947/data_sheet_c78-598933.html
and about SFP+ slots check out this compatibility matrix of SFP's versus the module, Switch & IOS
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp139452
Hitesh Vinzoda
Please rate useful posts
Thx Hitesh for clarifying this as this was also important for me. Your info is more accurate than mine, so you have 5 points from me.
Calin
Thanks bro...
I appreciate that..
Hitesh Vinzoda
