queue length zero
Dennis Olvany
Level 2
Level 2
In the course of troubleshooting some transmit discards I noticed something peculiar. The output queue length on the discarding interfaces is 0. Shouldn't this be the default length of 40?
GigabitEthernet0/18 is up, line protocol is up (connected)
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:06, output 00:00:11, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 304756
  Output queue: 0/0 (size/max)
  5 minute output rate 49701000 bits/sec, 5580 packets/sec
     3334146093 packets output, 3193609832897 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
6 Replies 6
ranraju
Hi Dennis,
Yes the max size of the output queue is 40. And from the show interface output you are seeing 0/0 - which is incorrect and its a cosmetic issue. Its a buggy behavior, and there are also known bugs for this issue. You see drops incremeting only in "show int", but in "show platform port-asic stats drops" you will not see these drops, as these are the outputs from the hardware. To get a resolution for this issue, upgrade to the lastest available version in that platform.
Hope this answers your query on the post.
(please rate helpful posts)
ranraju
Thanks for the info. I don't suppose you would know the bug id. I didn't find a match in the toolkit.
what platform is this? also tell me the version of code that you are running, will see if i can find the bug ID. But however, eventually you have to upgrade the switch, and upgrading it to the latest version available is always a good idea, as a lot of bugs would already be fixed in it.
ranraju
Cat3560 and cbs3020 both running 12.2.50se3.
You might want to take a look at this bug, CSCsz61947.
It was seen on 3750, with version 12.2(50)SE or 12.2(50)SE1.
The fix is in 12.2(52)SE, so you could either upgrade to this version, or as i mentioned to the latest available version.
ranraju
Thanks, I am going to upgrade the ios. I'll let you know the results.
