Queue-limit with shaping
dan.letkeman
Level 7
Level 7
I have a 2921 where I am shaping some traffic based on subnet on my lan.  I have applied the shaping policy to the lan interface in the outgoing direction.
Topology is as follows:
ISP - ASA - ROUTER - LAN
Policy map:
Policy Map shape-lan
  Class tc-class
    Average Rate Traffic Shaping
    cir 5000000 (bps)
    queue-limit 4096 packets
I am seeing a lot of no-buffer drops on the policy and I am wondering what the best solution is to solve this:
Class-map: tc-class (match-any)
   8730680 packets, 10803689863 bytes
   5 minute offered rate 4453000 bps, drop rate 0 bps
   Match: access-group name tc-class-acl
     5 minute rate 4453000 bps
   Queueing
   queue limit 4096 packets
   (queue depth/total drops/no-buffer drops) 2/33819/33819
   (pkts output/bytes output) 8248711/10303551681
   shape (average) cir 5000000, bc 20000, be 20000
   target shape rate 5000000
Should I just be increasing the queue-limit or should I be chainging something else?
Dan.
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
dan.letkeman wrote:
Ok, so I added the fair-queue command with a 1024 dynamic conversation queues, and now I didn't have any no-buffer drops but just some flowdrops.  This could be due to a limted about a traffic today, but it seemed better with a smaller queue limit and the fair-queue command
  7403270 packets, 9285635494 bytes
  5 minute offered rate 0 bps, drop rate 0 bps
    5 minute rate 0 bps
  Queueing
  queue limit 1024 packets
  (queue depth/total drops/no-buffer drops/flowdrops) 0/479/0/479
  (pkts output/bytes output) 7402791/9285046664
  Fair-queue: per-flow queue limit 256
              Maximum Number of Hashed Queues 1024
Would this be happening because its just to congested?
Dan.
That would be my expectation.  The big difference between the types of drops, I believe the no-buffer drops would effectively be global tail drops while the flow drops would be specific to a flow or flows.  I.e. the latter shouldn't drop against non-congestion creating flows.
If your results hold, and you're concerned about these drops, what you could do is experiment a bit by increasing queue-limit until no-buffer drops reappear and back-off again.
BTW, drops are often normal with congested interfaces and can be actually "constructive" in that they provide feedback to TCP flows to slow their transmission rate to available bandwidth.  That said, ideally you still want the minimal number of drops to provide this feedback and you only want to target the "offending" congesting causing flows.
12 Replies 12
Joseph W. Doherty
Disclaimer
Posting
What's your buffer stats look like?
Buffer elements:
     748 in free list (500 max allowed)
     7206263 hits, 0 misses, 617 created
Public buffer pools:
Small buffers, 104 bytes (total 51, permanent 50, peak 98 @ 1w2d):
     46 in free list (20 min, 150 max allowed)
     5451136 hits, 51 misses, 76 trims, 77 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 46 @ 1w2d):
     24 in free list (10 min, 150 max allowed)
     1531925 hits, 10 misses, 30 trims, 30 created
Big buffers, 1536 bytes (total 50, permanent 50, peak 59 @ 1w0d):
     49 in free list (5 min, 150 max allowed)
     6356469 hits, 12 misses, 37 trims, 37 created
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 1w2d):
     10 in free list (0 min, 100 max allowed)
     19 hits, 0 misses, 1 trims, 1 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 1w2d):
     1 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 86 trims, 87 created
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 1w2d):
     5 in free list (4 min, 10 max allowed)
     0 hits, 0 misses, 171 trims, 176 created
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 1w2d):
     101 in free list (132 min, 132 max allowed)
     13858 hits, 0 misses
IPC buffers, 4096 bytes (total 2, permanent 2):
     1 in free list (1 min, 8 max allowed)
     1 hits, 0 fallbacks, 0 trims, 0 created
IPC Medium buffers, 16384 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
IPC Large buffers, 65535 bytes (total 2, permanent 2):
     0 hits, 0 misses, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 512 in cache
     652633530 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 1664 bytes (total 1536, permanent 1536):
     1024 in free list (256 min, 2048 max allowed)
     910 hits in cache, 0 misses in cache
Normal buffers, 1676 bytes (total 3840, permanent 3840):
     3840 in free list (128 min, 4096 max allowed)
     34400566 hits, 0 misses, 0 trims, 0 created
Private particle pools:
HQF buffers, 0 bytes (total 2000, permanent 2000):
     2000 in free list (500 min, 2000 max allowed)
     7926407 hits, 0 misses, 0 trims, 0 created
IDS SM buffers, 240 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     128 hits, 0 fallbacks
     128 max cache size, 128 in cache
FastEthernet0/0/0 buffers, 1548 bytes (total 128, permanent 128):
     128 hits, 34400566 fallbacks
     128 max cache size, 64 in cache
     829203555 hits in cache, 34400502 misses in cache
GigabitEthernet0/0 buffers, 1664 bytes (total 1024, permanent 1024):
     0 in free list (0 min, 1024 max allowed)
     1024 hits, 0 fallbacks
     1024 max cache size, 442 in cache
     441985102 hits in cache, 0 misses in cache
GigabitEthernet0/1 buffers, 1664 bytes (total 1024, permanent 1024):
     70 in free list (0 min, 1024 max allowed)
     1024 max cache size, 957 in cache
     800575588 hits in cache, 910 misses in cache
GigabitEthernet0/2 buffers, 1664 bytes (total 1024, permanent 1024):
     1024 max cache size, 768 in cache
     551000 hits in cache, 0 misses in cache
Disclaimer
Posting
Those stats look good, which likely means your shaping queue buffers don't count against them.
What's your free memory look like? (You're requesting about 6 MB just for these buffers.)
What's the MTU on the shaped interface?
PS:
BTW, the solution might be decreasing your queue-limit.  The no-buffer drops infers you don't have enough memory to support your requested 4096 buffers.
Memory looks fine.  At least it never went too low.
                      Head      Total(b)          Used(b)       Free(b)        Lowest(b)    Largest(b)
Processor   2A67AFC0   320360512    52742812   267617700    51790492   228353424
          I/O    D800000    41943040       20036880    21906160    21864320    19549308
MTU:
GigabitEthernet0/0 is up, line protocol is up
  Description: LAN
  Internet address is 10.10.10.1/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 5/255, rxload 1/255
Disclaimer
Posting
Those look good too, so at least to me, not obvious why you're getting buffer failures.
What do I look for in the show buffers command when I am seeing drops?
Disclaimer
Posting
I was looking at the "# failures (# no memory)", but all yours show zeros.  You also appear to have ample free RAM.
PS:
This paper, http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a0080af893d.shtml, mentions its possible to have no-buffer drops pass some interface limits.  You might try setting queue-limit down, as both Kishore and I suggested; perhaps try 1024.
Thanks.  I will give that a try.  I was watching it today, but there were no drops at all even with the queue-limit at 4096.
Disclaimer
Posting
My guess would be that today your buffers didn't need to go deep enough to hit the exhaustion condition.
    5 minute rate 0 bps
  Queueing
Dan.
Disclaimer
Posting
    5 minute rate 0 bps
  Queueing
Dan.
hi  dan,
maybe try decreasing your queue limit and see if that helps
