Policy based routing problem - not done in hardware ?
shanopano
I am having a problem with PBR done on a 7604-S router - It seems like it is not done in harware. I have an Iperf client and an Iperf server, and would like to test the performance of 7600 router for PBR, supervisor is RSP720-3C-G and used interface card is 7600-ES20-GE3C ESM20G.
I have read  numerous discussions about PBR that is supposed to happen in hardware when you use it with matching access-list and set ip next-hop.
Although, when I start the iperf, the 7600 cpu is hitting the 80-90 % boundary, and transfer bandwidth can't go over 120-130 Mbit/s.
The IP Policy is applied on an interface part of vrf ONE maybe this is casing the problem... ?
Any suggestions are welcomed.
The diagram and configuration follows:
Configuration:
c7604#sh run
boot system flash disk0:c7600rsp72043-advipservicesk9-mz.122-33.SRE2.bin
ip vrf one
rd 1:1
vlan 100
name users2
!interface GigabitEthernet4/0/0
ip vrf forwarding one
ip address 192.168.30.1 255.255.255.0
ip flow ingress
ip policy route-map 1
load-interval 30
no mls qos trust
interface GigabitEthernet4/0/1
mac-address 2222.2222.2222
ip address 192.168.31.2 255.255.255.252
speed 1000
no mls qos trust
interface GigabitEthernet4/0/2
ip address 192.168.31.1 255.255.255.252
ip nat inside
speed 1000
no mls qos trust
interface GigabitEthernet4/0/3
ip address 91.x.x.x 255.255.255.252
ip nat outside
speed 1000
no mls qos trust
interface GigabitEthernet4/0/4
description Internal to SMC p24
ip address 192.168.20.46 255.255.255.0
ip nat outside
speed 100
no mls qos trust
interface GigabitEthernet4/0/10
switchport
switchport access vlan 100
switchport mode access
speed 1000
no mls qos trust
interface Vlan100
ip address 192.168.40.1 255.255.255.0
access-list 10 permit 192.168.30.0 0.0.0.255
route-map 1 permit 10
match ip address 10
set ip next-hop 192.168.31.1
8 Replies 8
shanopano
Nothing changes when I configure the ip route-cache policy on the PBR Interface Gi4/0/0.
Results are as before:
CPU utilization for five seconds: 89%/40%; one minute: 20%; five minutes: 5%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
216      631296     2894561        218 47.59% 10.25%  2.29%   0 IP Input
Edison Ortiz
Post the output from typing:
show tcam interface gig4/0/0 acl in ip
Here is the output:
c7604#sh tcam interface gigabitEthernet 4/0/0 acl in ip
* Global Defaults shared
Entries from Bank 0
Entries from Bank 1
    permit       ip any 224.0.0.0 15.255.255.255
    punt         ip 192.168.30.0 0.0.0.255 any
    permit       ip any any
c7604#
This
indicates the traffic that matches this entry will be punted to the CPU.
I believe it has to do with the fact the 'ip next-hop' in your PBR is set to the router itself.
It must point to a device attached to this router.
shanopano
Seems like PBR in VRF is causing the problem, as I moved the VRF ONE from the Iperf client side to Iperf Server side of the setup - Gi4/0/0 and Gi4/0/1 to Gi4/0/2 and Gi4/0/10.
Now I am able to reach nearly 900 Mbit/s with 3 iperf sessions and the 7606 cpu stays below 1 %..
Freaky thing is when I issue the debug ip policy, I am not getting policy routed packets showing as expected, the ACL doesn't have a sigle match and route-map counters are not incrementing...seems very stange to me.
In the global routing table there is no route to 192.168.40.0 network so traffic must be policy-routed... no other way for the packets go...and in VRF ONE I have a default-route pointing to gi4/0/1's ip 192.168.31.2 for the way back.
When a service is running in hardware, you won't be able to capture information via debugs. Only when a service runs in software, the debugging feature will show output and the route-map counter will increment.
BTW, per your original config, 192.168.40.0 is in the Global Routing Table with SVI 100.
Edison
I am pretty sure to get this to work in your original configuration in hardware you would need to do it like this:
match ip address 10
set ip vrf one next-hop 192.168.31.1
-Matt
Thanks Matt,
with the addition of the vrf keyword in the route-map all works fine, PBR is done in hardware and everything seems OK.
Thanks to all that gave suggestions.
Greets,
Ruslan
