Quick EIGRP quirk
Ricky Sandhu
Level 3
Level 3
Hey guys, quick EIGRP question for ya. I am still brushing up on my EIGRP so my appologies if this is just a common sense question.
I have a hub and spoke network with DMVPN connectivity with 2 hubs (Hub A and Hub B) and approx. 60 spokes.
Each of these spokes only connects to Hub A (for now) via their local Tunnel0 interface however I have 1 spoke (Spoke X) which also connects to Hub B (simultaneously) over it's local Tunnel1 interface.
At the data center, Hub A and Hub B, each having it's own public interface, also connect to each other via a common switch (for failover reasons).
Hub B knows all of its routes to the spokes via Hub A i.e. through Hub B's interface (GigE0/2) connecting to the switch.
However there are 4-5 spoke routes it is learning via Spoke X since X connects to Hub B (as explained above).
How can I fix this without having to put a static route statement in Hub B to point it to GigE0/2 for those spokes?
Thanks in advance
viswamin
if any routes are learned via spoke. you can configure the spoke as a "STUB NETWORK" so that it does not form a transit path for any of the routes.
-Vijay
7 Replies 7
Hi Ricky,
If I understood well you have 59 spokes connected to HUBA and 1 spoke connected to HUBA and HUBB
If this issue apears only to some spokes, I belive that you have some filtering in place on HubA to HubB or on B from A, or
some summarization of those spokes on HubA on the interface to Hub B or some metric offset set for this spokes.
Can you post "show ip eigrp topology SPOKE_LEARND_VIA_SPOKE_X" on HubB.
Also it would be helpfull to the the eigrp config of the Hubs with interface between the hubs config
Dan
Hi Dan, here you. Please let me know if you need more information. I just took over this position from a previous network engineer that left the company. Just tring to clean up the mess
______________________________________________________________________________
***HUB B IP route statement for INCORRECTLY learned route and the EIGRP top***
HUB-B#sh ip route 172.18.2.1
Routing entry for 172.18.2.0/24
  Known via "eigrp 1", distance 90, metric 17920256, type internal
  Redistributing via nhrp, eigrp 1
  Last update from 10.10.201.27 on Tunnel0, 11:30:06 ago
  Routing Descriptor Blocks:
  * 10.10.201.27, from 10.10.201.27, 11:30:06 ago, via Tunnel0
      Route metric is 17920256, traffic share count is 1
      Total delay is 600010 microseconds, minimum bandwidth is 1000 Kbit
      Reliability 255/255, minimum MTU 1400 bytes
      Loading 255/255, Hops 3
HUB-B#sh ip eigrp topology 172.18.2.0/24
EIGRP-IPv4 Topology Entry for AS(1)/ID(1.1.1.2) for 172.18.2.0/24
  State is Passive, Query origin flag is 1, 4 Successor(s), FD is 17920256
  Descriptor Blocks:
  10.10.201.27 (Tunnel0), from 10.10.201.27, Send flag is 0x0
      Composite metric is (17920256/15360256), route is Internal
      Vector metric:
        Minimum bandwidth is 1000 Kbit
        Reliability is 255/255
        Load is 255/255
        Minimum MTU is 1400
        Hop count is 3
***HUB B IP route statement for a CORRECTLY learned route***
HUB-B#sh ip route 172.18.24.1
Routing entry for 172.18.24.0/24
  Known via "eigrp 1", distance 90, metric 2560512, type internal
  Last update from 172.18.123.2 on GigabitEthernet0/2, 11:29:42 ago
  * 172.18.123.2, from 172.18.123.2, 11:29:42 ago, via GigabitEthernet0/2
      Route metric is 2560512, traffic share count is 1
      Total delay is 50020 microseconds, minimum bandwidth is 2000 Kbit
      Loading 255/255, Hops 2
***HUB B EIGRP Config snippet***
interface Tunnel0
bandwidth 1000
ip address 10.10.201.1 255.255.255.0
no ip redirects
ip accounting output-packets
ip mtu 1400
no ip next-hop-self eigrp 1
ip nhrp authentication Trow!
ip nhrp map multicast dynamic
ip nhrp network-id 201
ip nhrp holdtime 600
no ip split-horizon eigrp 1
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 201
tunnel protection ipsec profile profile1
interface Tunnel2
ip address 10.10.202.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 202
ip nhrp registration no-unique
tunnel key 202
tunnel protection ipsec profile profile2
interface GigabitEthernet0/0
description OUTSIDE
ip address ***.***.***.*** 255.255.255.240
ip access-group BLOCK in
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/2
description Switch-G2/0/24
ip address 172.18.123.3 255.255.255.0
duplex auto
speed auto
standby 123 ip 172.18.123.1
standby 123 priority 90
router eigrp 1
network 1.1.1.2 0.0.0.0
network 10.10.201.0 0.0.0.255
network 10.10.202.0 0.0.0.255
network 172.18.123.0 0.0.0.255
redistribute static route-map STATIC-TO-EIGRP
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ***.***.***.***
ip route 172.18.120.0 255.255.255.0 172.18.123.250
ip route 172.18.121.0 255.255.255.0 172.18.123.250
ip route 172.18.122.0 255.255.255.0 172.18.123.250
ip access-list standard STATIC-TO-EIGRP
permit 172.18.120.0 0.0.0.255
permit 172.18.121.0 0.0.0.255
permit 172.18.122.0 0.0.0.255
access-list 23 permit 172.18.0.0 0.0.255.255
route-map STATIC-TO-EIGRP permit 10
match ip address STATIC-TO-EIGRP
***HUB A EIGRP Config snippet***
interface Tunnel0
bandwidth 2000
ip address 10.10.200.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 200
tunnel key 200
tunnel protection ipsec profile Profile1
description OUTSIDE
duplex auto
speed auto
interface GigabitEthernet0/1
description int
no ip address
shutdown
duplex auto
speed auto
description Switch-G1/0/24
ip address 172.18.123.2 255.255.255.0
duplex auto
speed auto
standby 123 priority 110
standby 123 preempt
standby 123 track 1 decrement 30
router eigrp 1
network 1.1.1.1 0.0.0.0
network 10.10.200.0 0.0.0.255
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.0.10.0 255.255.255.0 172.18.123.250
ip route 10.10.5.0 255.255.255.0 172.18.123.250
ip route 10.102.154.0 255.255.255.0 172.18.123.250
ip route 172.18.0.0 255.255.255.0 172.18.123.250
ip route 172.18.4.0 255.255.255.0 172.18.23.250
ip route 172.18.10.0 255.255.255.0 10.10.200.19
ip route 172.18.11.0 255.255.255.0 172.18.123.250
ip route 172.18.70.0 255.255.255.0 172.18.123.250
ip route 172.18.168.0 255.255.255.0 172.18.123.250
ip route 192.168.2.0 255.255.255.0 172.18.123.250
ip route 192.168.220.0 255.255.255.0 172.18.123.4
ip route 192.168.254.0 255.255.255.0 172.18.123.250
permit 172.18.11.0 0.0.0.255
permit 10.102.154.0 0.0.0.255
permit 10.120.120.0 0.0.0.255
permit 192.168.254.0 0.0.0.255
permit 10.10.5.0 0.0.0.255
access-list 5 permit 172.18.120.0 0.0.0.255
viswamin
-Vijay
Yes this is a very nice solution,Vijay
But if there is any fitering between A and B won't solve it.
Dan
Hi Vijay, if I add the Eigrp Stub command in the EIGRP portion of the config on a live router, that would've cause a connection drop would it?
Yes. When you configure the spoke as STUB, then the neighborship goes down and comes back..
If you dont want the neighborship, then we can filter the route using prefix list ..
May be Experts would have some more thoughts as I'm still learning ....
-Vijay.
Thanks Vijay. EIGRP Stub command seemed to have fixed the issue.
