QUick suggestion on OPtic fibre connectivity
srikanth ath
Level 4
Level 4
we are using GLC-SX-MM module to,  Multimode fiber 50u OM3 to connect branch office to Head office (disatance apart 200mts). The fiber has LC type connectors on both side, and we  are connecting to the Cat3750(L3) switch to CAT 2960(L2 + 2 sfp combo slots).
switch(3750)>LC--------Fiber-------LC<switch(2960).
laying out the cable patches everything is done.
now i have to do the testing and connectivity part. how should be done.
1. cat 3750 is a dhcp server to branch office(we are giving mac based binding for branch office).
test ?
1. should the ports connected(2960 to 3750)  has to be made trunking to carry vlans or does it do automatically(as by default  the ports are trunk)
2. how to verify the ports are connected correctly (1. way is to see the led lights on both ends) and how can i check through commands
3.what all the different commandds i can run on these ports.
quick suggestion please as i have very less time to get it done practically.
thanks & regards
srikanth
srikanth ath
Level 4
Level 4
QUick reply please
1. should the ports connected(2960 to 3750) with fibre  has to be made trunking to carry vlans to each other..
thanks
srikanth
if the link carries multiple vlans traffic then the port should be configured as trunk on both sides.
conf ter
inter <>
sw tr encap dot1q
sw mo tr
exit
To check the links are working fine or not, use the below commands
sh int status
sh int trunk
sh interfaces | i line|rate|up
Hope this helps
Cheers
Somu
Rate helpful posts
thanks somu
then what about the speed .. should i have to manually configure anything to speed
like auto negotiation.
full duplex
regards
srikanth
pls configure speed auto, duplex full.
When you issue the command show interface <> capabilities you can see the port speed & duplex capabilities.
sample output:
Switch-A#show interface Gig4/3 capabilities
GigabitEthernet4/3
Model                    WS-X4516-10GE-Gbic
Type                     1000BaseT
Speed                    1000
Duplex                   full
Hope this answers your question.
Cheers
Somu
Rate helpful posts
