"Configuring IP routing on a LAN subinterface is only allowed" Issue
taymur naeem
Hi team, Hope everything is well.
I am facing an issue for some days. I have a configuration file, that i am trying to convert into SD WAN templates using a Conversion tool. This tool has a Network Emulator Device (NED) that validates the configuration file.
This NED is not an actual device, It just take configuration line by line and validate it. Now in configuration file, i have Interface Port channel block.
When this block starts validating in NED, at the encapsulation dot1Q 1 command, the NED breaksdown and its CLI gets restarted.
If i remove that line, i start facing error "Configuring IP routing on a LAN subinterface is only allowed if that subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q, or ISL VLAN" ... I know that encapsulation command is used to assign the interface with VLAN, But this NED doesn't retain any VLAN configuration.
Can anyone please guide how to resolve this issue ?
balaji.bandi
you need to provide mode information tool and configuration example.
BB
